So I made a cnc machine out of a bunch of aluminum, steel, and v-slot rail.
But it has an issue. For some reason, despite a 54V power supply for the steppers, and triple stack nema 34 (one for X, two for Y) motor, it can't go very fast? The motors manage about 200rpm before going into unhappy vibrate mode. They are not even really being loaded, either. The machine is very low friction, and the screw drive isn't hard to turn either. Acceleration is not it, either, even when I turn it way down, it still does it. I am using CW250 5A stepper drivers (which I hope aren't the problem, but alas, I assume they are, but I'm not sure how to fix this)
The issue with this is that with the 1/2-10 acme screws, the machine has a top speed of 20IPM. Which is very slow.
Anyone know why this is a thing? The drivers are set to 8x microstepping, acceleration doesn't affect it either.. Slow or fast, it still has the issue.
