587,920 active members*
3,295 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > OOYA RE-OM with Fanuc 6T control DC Spindle Drive problem
    Jan 2016
    1
    Hello.
    I'm Trying to determine the problem with FANUC 6T Servo Drive unit.
    Board A20B-0008-037
    Everytime, when machine get the command to run spindle drive FA1 FA2 FA3 alarm fuses om that board, are blown randomly. Sometimes is only blow FA1 or 2 or all three together. Then i got an Red Light (Spindle Motor) on main panel.
    We already tried to replace spindle motor. No luck.
    Any help?
    Thanks.
    Sep 2010
    125
    Re: OOYA RE-OM with Fanuc 6T control DC Spindle Drive problem
    YOUR DRIVE PCB 0375 IS DEFFECTIVE , SURE !
    Check the main fuses the alarm fuses are in parallel the main fuses, they indicate when the main fuses are blown
  1. Replies: 2
    Last Post: 06-23-2014, 07:59 AM
  2. Fanuc/Hurco Spindle Drive Problem
    By gregm1976 in forum Fanuc
    Last Post: 12-18-2013, 08:52 AM
  3. Replies: 3
    Last Post: 02-02-2012, 02:51 PM
  4. Fanuc 6T spindle drive problem
    By quizzze in forum Fanuc
    Last Post: 12-03-2008, 04:31 PM
  5. Fanuc O-Tc AC Spindle Motor Drive Problem
    By suleman_mani in forum Fanuc
    Last Post: 10-29-2008, 02:28 AM
