I am gonna go with belt. The large plate is to hold the L shaped bracket that will hold the belt using a belt clamp. The stepper will be stationary at the head of the machine. Ill use a drive shaft that will go to the other side of the cnc. The reason I am using the long aluminum plates on the side are to be able to lower the belt and drive shaft so thats its not in the way of the front of the machine and I can put a guard over the shaft.
I am at work now or Id post a photo of what I mean.
Thanks for looking.
Joe, I kinda like the rack and pinion Idea. Would I have to gear the stepper down maby?
Steve
