The OMNI 5 axis cnc router china is with an extra heavy duty gantry and machine table for maximum rigidity and strength to provide high speed machining in all 5 axis. Due to the flexibility of the OMNI 5 axis cnc router china machining centre is commonly used for mould making, machining moulds in wood, resin tooling board, EPS and composites, trimming of vacuum formed mouldings, plastic fabrication, GRP machining, props and model making, profiling, solid surface machining and contouring, various large metalloid mould, especially suitable for automotive foam mold, wooden ship model, wooden model aviation, rail wooden mold, wooden mold train.Instrument industry: 3-d surface engraving and shape cutting of large-scale instruments.
5 axis cnc router china working Area (in 5 axis): 1100 x 2300 x 900mm and 1200 x 2400 x 900 in 3 axis
Extra heavy duty welded steel frame and gantry for maximum straightness and rigidity
10Kw HSD Spindle
8 position rotary ATC with HS655 precision tool clamping
THK made in Japan lubricated for life linear rails and guide blocks
Imported ball screw on x axis ensures processing accuracy
Yaskawa servo drivers and motors for high power and speed
Osai - PC interfaced Numerical Control System
T-Slot clamping table
Becker vacuum pump for vacuum clamping fixtures (optional)
Oil Mist cooling system for cutting non-ferrous metals (optional)
3.0Kw Single bag 3-phase dust extractor or 5.5kw dual bag 3-phase dust extractor (optional)
Please contact us cnc wood router-cnc wood router|china cnc router|rouercnc-omni cnc if you have any question about omni 5 axis cnc router china.
