586,055 active members*
4,221 visitors online*
    Dec 2010
    126
    OMAX 55100 Head Vibration Issues
    Hey everyone,
    We have an OMAX 55100 with tilt-a-jet. We have always had a little bit of vibration in the head along the X-Axis but recently it has gotten significantly worse. We always used to attribute it to the cantilever design, but it is definitely getting worse. This happens even without the pump running, so it isn't some kind of resonance issue.
    We replaced the old cracked timing belts for both X and Y, replaced the tail bearings for both X and Y and lubed every lube point on both axes until they ran clean grease only. We have checked every bearing, surface and drive point that we can think of and haven't been able to reduce the vibration. Applying pressure in any direction to the end of the cantilever doesn't seem to affect it either, though the head is heavy enough that applying pressure by hand doesn't do much.
    Has anyone ever had issues like this? Naturally OMAX wants to send a tech out to inspect the machine, but our pocketbook is already light right now. Having a tech come to our facility seems to always be a $2500+ ordeal BEFORE parts are factored in. I just want to be sure I've exhausted every option before we go that route.
    Thanks for reading!
    I AM GLAD TO TAKE THIS OPPORTUNITY TO INTRODUCE OURSELVES AS ONE OF THE LEADING SUPPLIERSOF PRECISION BEARINGS
    MAINLYAPPLY FOR CNC AND MACHINE TOOL AND OTHER PRECIAION MACHINARY , WHICH ARE MAKE OF WAFANGDIAN TIANJIU BEARINGS TECHNOLOGY CO.,LTD.
    WE DEVELOP HIGH-PRECISION YRT ROTATED BEARINGS, MACHINE TOOL MAINSHAFT BEARINGS AND MOTOR PRECISION BEARINGS. THEPRECISIONS OF OUR BEARINGS HAVE REACHED LEVELS OF P5, SP, P4 AND UP.
    WE HOPE CAN CORPORATION WITH YOUR COMPANY.IF ANY RELATED INQUIRY,PLEASE FEEL FREE TO CONTACT WITH US.
    WE CAN ALSO SUPPLY BEARINGS SAMPLE FOR YOUR AT FIRST.
    WE CAN SUPPLY OUR BEST PRODUCTS FOR YOU.
    THANK YOU !
    REGARDS!
    Lixingwen
    Wafangdian Tianjiu Bearings Technology Co.,Ltd.
    (Wafangdian Heavy Bearings Researching & Manufacturing Co.,Ltd.)
    Brand:WZFB
    Web: 瓦房店天久轴承科技有限公司(原 瓦房店重型轴承研究制造有限公司)
    Tel: 0411-85366785
    Fax: 0411-85366785
    Mobile:+86-15942617721
    E-mail:[email protected]
    Q Q : 178702120
    Skype: lixingwen1987
    Do our best to give customer best service.
    Apr 2006
    3206
    Re: OMAX 55100 Head Vibration Issues
    Quote Originally Posted by Japazo View Post
    Hey everyone,
    Thanks for reading!
    Have you gotten the vibration issue resolved?
    We have a brand new Omax and there is a little vibration.... The factory guy is looking into it...
    Was wondering if it's symptomatic.
  1. mill head vibration
    By joshuaz2 in forum Uncategorised MetalWorking Machines
    Last Post: 12-14-2012, 01:18 AM
  2. Amount of axis in rotary head of OMAX Tilt-A-Jet
    By Mr Helmut in forum Linear and Rotary Motion
    Last Post: 08-24-2012, 02:24 AM
  3. OMAX Files
    By steeler1933 in forum Waterjet General Topics
    Last Post: 05-04-2010, 03:47 PM
  4. How much head vibration SX3/X4?
    By iGG1e in forum Syil Products
    Last Post: 08-06-2009, 06:11 AM
  5. Chatter vibration issues
    By Designsync in forum DIY CNC Router Table Machines
    Last Post: 02-15-2008, 12:10 PM
