586,031 active members*
2,826 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA OSP 5020 GRAPHIC VERIFY?
Results 1 to 7 of 7
    Nov 2008
    47
    Looking for help on how to verify a program made by my cam system on my Okuma LNC 8 lathe with osp5020 control.
    Feb 2009
    6028
    Re: OKUMA OSP 5020 GRAPHIC VERIFY?
    Does the cadet have graphics? You can always machine lock and hit cycle start.
    Dec 2008
    3109
    This is a little trick to check the integrity of a program, ie 0 (zero) instead of O, comp errors, etc
    - do a restart to the end of the program using a number greater than the number of lines in the program
    ie RS 9999
    this should also display on the graphics screen, the 9999 is number of sequence ops to process, not the line numbering
    This should work in most controls
    Mar 2009
    1982
    1. Lock the machine. Must be a tumbler "Machine Lock"
    2. You can switch on the "Dry Run" also. Must be a tumbler "Dry Run"
    3. Auto mode.
    4. Call the program to execution (F1)
    5. Go to animation screen. Adjust the scale and origin. "Auto" is good, if present.
    6. Push the green button: execute the program with machine locked.
    Nov 2008
    47
    I do have graphics.
    Ok, I thought it might be something with machine lock or dry run but when I try to select those buttons the interlock button flashes on. I have also tried this with the key in all positions and still doesn't seem to work. Is there a parameter I need to change?
    Feb 2009
    6028
    No, you hold down the interlock (I L) button and press dry run or machine lock.
    Mar 2009
    1982
    it's dangerous. You need to know what and when to push.
    If you can place a picture of your control panel here.
  1. Replies: 2
    Last Post: 08-18-2014, 04:09 PM
  2. Okuma 5000/5020 12" monitor LCD replacement and more
    By monitor_guy in forum For Sale Only
    Last Post: 01-13-2014, 06:42 PM
  3. Okuma GKN 5020 Automatic Door Modification
    By ceilingwalker in forum Okuma
    Last Post: 05-22-2010, 08:33 AM
  4. okuma lt 15 m 5020 newb question
    By fabshop in forum Okuma
    Last Post: 04-30-2009, 06:18 PM
