587,089 active members*
2,970 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma Multus B300W Problem
    Aug 2013
    1
    Hello,
    I have a Multus B300W and I need help. When I power the machine up it goes to the windows screen and has a 7006P Alarm Backup Data File Error 40004. Has anybody experienced this? Can anybody help me? I can hit Ok and it goes away, but the machine does not finish booting up.
    Thank You!
    Mar 2009
    1982
    check hdd and read manual about full re-installation
    Mar 2006
    45
    My Macturn is an E100 so my problem may have been different. I don't recall the error it threw but once during power down (or up) it wiped the contents of one of the compact flash cards, taking all of my parameters with it.
    Okuma had a good tech here at the time. He read the CF card (not sure if the newer controls still use them) in a computer and found it had been wiped clean. He restored what he could from factory disks and the recalibrated the rest. It took him more than a day to do it from what I remember.
    He never found the cause. I think I am still running the same CF, he backed it up in case it failed again but it never has since. At that time I made it std procedure to PIP out a parameter file, verify it and copy it to my server before every power down.
    Hope you track it down.
    Kev
  1. Multus B300W Sub Spindle Center issues.
    By Ecmdrw5 in forum Okuma
    Last Post: 09-29-2021, 08:25 AM
  2. Multus B300W fiasco
    By mstlouis in forum Okuma
    Last Post: 06-29-2019, 10:28 AM
  3. Okuma Multus B300W Post Needed
    By Ecmdrw5 in forum Post Processors for MC
    Last Post: 08-26-2011, 01:31 PM
  4. Replies: 6
    Last Post: 02-10-2011, 07:06 AM
  5. Best cam for multitasking Okuma B300W
    By 3dman in forum Uncategorised CAM Discussion
    Last Post: 09-16-2008, 07:35 PM
