Hai...
Recently multus b300 had a serious collision and caused B-axis curvic clamp position runout, main spindle headstock runout and also turret X center runout... So far B-axis curvic clamp and headstock aligned in machine spec.
Turret X center i try to adjust using X & Y axis. Using dial gauge on test bar that fixed on M-spindle and adjust in 0.005mm tolerance. Cal the actual position in system parameter X & YI.
1st problem
Now the YI value not same for both spindle and its caused an alarm when switch the main or sub spindle.
Alarm - 4305 ALARM-D Y-Axis not turning position.
2nd problem
After center adjustment, test piece results center out 0.670mm.
Check again the center, dial gauge results is -0.046mm since in previous adjustment it was +0.005mm.
Please let me know that the method i used for adjust X center is correct or not.
If no kindly advise me the correct method.
How to solve the alarm?
Please share your experience.
Thank you
Vkrau.
