Hello all. I have an Okuma MA-650 Milling machine......well 2 of them.......that are doing some strange things. Every now and then when you try and load a new program from a post the machine will freeze and you need to reboot the machine. Sometimes it will work and sometimes not. I have swapped almost every component with a functional machine but the problem persists. I was able to get it running by changing the IP address to the machine. It ran for about a month but the issue has returned. I am at a crossroads and not sure what to do next. Also, any recommendations of a service provider for these types of machines in the GTA area? Someone that can provide on site service and parts.
Thanks all.
