I have an old LC40 we don't use too much except for a few jobs... hasn't been run in a few weeks. I turn it on, load up material, set my Z offset and hit go. Spindle doesn't start, and the tool comes and clips the front of the workpiece.
So I spent an hour messing with it to try and nail down the problem. I am baffled...
-In manual mode, I can jog the X and Z axes no problem (either with the +/- buttons or manual pulse wheel).
-If I go into MDI mode and type "G0 X1 Z1", it will go to about 1" away (in +Z) from the center of the collet, and it looks like it's right at X0
-If I type G0 X10 Z20 it goes to just about the same spot
-If I try to run a program, the spindle doesn't start, the turret moves to that same spot and just sits there
-No error codes on the screen, nothing on any of the spindle drives, and nothing on the OSP5000 controller itself in the cabinet
-I've checked my main X and Z offsets, and they are what they should be.
-I can go into the Zero Set menu and set offsets no problem. But whatever I set the offset to, it doesn't seem to change where the turret moves to upon any G command
-If I use MDI and say G0 X1 Z1 and it goes to that position, I can't get it to move positively in the X or Z axes through G codes, no matter what numbers I use. So if I type G0 X1 Z1 and wait for it to move.. then type G0 X10 Z1, it won't move up in X. If I type G0 X1 Z10, it won't move in +Z. But I can switch to manual mode and use the handwheel or +/- buttons to move it in any axes I like.
-When it moves to near the chuck, I checked to be sure it's not sitting on any limits
-When I move it to the +X and +Z extents, and type G0 X? Y?, whatever I type for ?, it always seems to go to the same spot.
-This machine has absolute position encoders and I am not getting any errors... the numbers on the display are matching what my dial indicator says the machine is moving.
The only thing I can think is that a few weeks back I was trying (for the millionth time) to get RS-232 file transfer working. I changed a few parameters, but only ones which get changed for RS-232. I had written down everything I changed, so I set them all back to what they were before I changed anything, let it sit for a few minutes, then reset the machine - does the same thing.
I did a visual check of the cabinet looking for any loose wires, mice chewed wires, etc - nothing. Looks clean as a whistle.
I keep thinking it must either be the most bizarre problem ever encountered or something really idiotic that I am doing like forgetting I changed something or some switch I've hit with my elbow. But I can't think what would cause this. I've checked my programs and they are OK (and I can read and write programs no problem). For a moment I thought maybe I somehow put it in a metric mode and my inches were being taken as millimeters, but even if I do G0 X200 Z200 it still goes to that same spot. I even unplugged the RS232 cable in case it was something going on there. And I made sure the clamp-unclamp switches on the spindle are working. I can start the spindle no problem (at any speed) with M03 M44SXXXX, no problem there. Turret indexes OK (from either panel switch or MDI command).
It's just like no matter what program move I give, it just goes to that same spot about X0 Z1 and sits there indefinitely.
Any ideas?
