587,467 active members*
4,493 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma LB 15 - Fanuc Spindle Drive Alarm - AL-07
Results 1 to 4 of 4
    May 2007
    49
    I have a Okuma LB 15 lathe with OSP5000L-G control and Fanuc AC spindle drive type A06B-6055-H208 with top pcb type A20B-1001-0120. When spindle speed above 3000 rpm, the control gives alarm message 110 ALARM-A SDU 1. In spindle drive, it gives AL-07 alarm. I tried to correct the parameter in the spindle drive using the buttons MODE,UP,DOWN and DATA SET. But, it can not retain the data after power on. Only, it shows the old value. I could not see any data protect switch or jumper in the spindle drive. Can anybody give the procedures ? I do not have the manual for this drive. Can anybody give manual for this drive ?
    Feb 2009
    6028
    Been a long time, think you hold all 4 buttons until display flashes, change parameter you want, hold data set till display flashes(3 second)
    Sent from my G-Tab Quantum using Tapatalk
    May 2007
    49
    Thanks Underthetire. I am actually able to change the particular parameter after pressing the 4 buttons. After entering the parameter, I held the DATA SET button until the display shows '8888' as mentioned in one of the sites here. The data remains as changed until I make power off and on. After power off and on, the particular parameter value goes back to its previous value.
    May 2007
    49
    I could find a small jumper which can be put in 'SET' position from 'DRIVE' position to store the parameters. But, I have one more problem in the spindle drive. I will start a new thread for this. Thanks
  1. Fanuc dc spindle drive alarm
    By cabbage in forum Fanuc
    Last Post: 06-25-2013, 02:31 PM
  2. Fanuc ac spindle drive alarm#4
    By movick_25 in forum Fanuc
    Last Post: 01-16-2012, 04:45 PM
  3. fanuc spindle drive alarm no-10
    By r_mahesh77 in forum DNC Problems and Solutions
    Last Post: 09-12-2007, 04:22 PM
  4. Fanuc ac spindle drive alarm 01
    By suresh patil in forum DNC Problems and Solutions
    Last Post: 08-08-2007, 08:37 AM
  5. Spindle drive alarm in fanuc 16 ta
    By miguisu in forum Fanuc
    Last Post: 02-20-2007, 05:12 PM
