587,629 active members*
3,345 visitors online*
Page 1 of 2 12
Results 1 to 20 of 28
    Aug 2008
    10
    OKUMA FLOOPY DRIVE
    I have several machines that the floopy drives are ba or going bad. Does anyone know what needs to be done to a standard floppy drive to get it to work with the okuma machines like the LU100 or 7000.
    Thank you,
    Matt
    Feb 2009
    11
    Okuma uses a proprietary file sturcture as well as communication protocol for their floppy drives. You must use one of their floppy drives.
    Dec 2008
    3132
    Most Okuma's also have RS232 and standard "PIP" tramsfer,
    it may be wiser to run cables to the machines from a slave transfer server and eliminate floppies altogether
    or if needed DNC option fitted ( DNC option does cost $$$)
    The newer machines can be network capable
    Jun 2008
    372
    Any old standard floppy drive should work, Barring that you can setup a RS232 to Enthernet
    Aug 2006
    9
    Okuma Floppy Drives
    I can get the and have in stock most the time. Okuma 3 1/2 replacement floppy drives. Drop me a line if interested.
    Oct 2009
    119
    Hi everybody
    I am new in this forum. Very useful
    Okuma uses industrial floppy , Maker : YE data . This is different than others. But you can buy from okuma an external floppy drive.
    Dec 2008
    3132
    From PC shop ~ $50
    3.1/2" floppy --- external--- USB -----WHY ???
    this gives you 1.44Mb of data per disk
    Thumb drive up to 16GB are available, if you use 4GB stick, thats about 25 floppies
    Better and more reliable data transfers when you use cables ( RS232 or Ethernet )
    Oct 2009
    119
    Superman
    I mean for old machines. External floppy.
    Of course for new usb stick is better
    Apr 2008
    211
    Quote Originally Posted by Superman View Post
    From PC shop ~ $50
    How about a floppy emulator?I have a Dynapath controller with dead RS232 that needs a floppy upgrade.
    Has anyone tried to replace theirs with a floppy emulator?As far as I know the emulator has a regular floppy outlet at the back and a usb port at the front.It can be configured to look like a regular floppy to fool the controller into
    thinking its a floppy.
    Can it actually fool Okuma or Dynapath controllers yet has to be tried.
    Good luck!
    Apr 2008
    211
    Floppy emulator
    Here is the web page.
    http://www.ipcas.com/products/usb-fl...dd-to-udd.html
    They also have lots of other great toys
    Have fun!
    Dec 2003
    24220
    I have been asked by one of my customers to round up some floppy drives for his Okuma's, Just to be clear, can regular floppy drives be adapted, I would find it strange if Okuma used proprietary interface?
    Or has anyone actually hooked up the floppy - USB converter?
    What are the proven options?
    Al.
    Albert E.
    Apr 2008
    211
    Sorry can't help you out on this one.I've decided to save my dough and get a new motherboard so I can dnc.Breaking up my programs so they can fit on the floppy is getting old quick.I'd have the same problem fitting them on the emulator 1.44 max size but 100 of them if you like.
    I know only a teak floppy can be used to replace my existing one.I can only assume that if you replaced the floppy in your customer's machine by the same make and model it should work.
    Or models of emulators are now available in the US for half of what they were worth when I looked at them last year.
    Cheers!
    Oct 2009
    119
    Anyone using this
    http://www.plrelectronics.com
    Jan 2010
    8
    Hi guys,
    Here it is the very best solution, take a look..this is excelent!!
    Bye! Aro/
    If you are using Floppy Disk on your equipment/machine you know that the Floppy´s are not a safe way to save your programs, and also they are close to disappear of the market.
    FlexiDriveS4
    No more Floppy Disk´s !
    Increase the reliability of your equipment.
    Allow to save in a safety way your files and programs.
    Reduce faults and down times in your process.
    Features
    •Replace 3 ½ floppy drives on any equipment / machine.
    •Developed for old industrial equipment that are not obsolete and still in production.
    •CNC Machines, Electromedicine, Textile machines, Industrial Systems, Robotsetc.
    •Easy to install / Easy to Use.
    •SD / microSD / SDHC / MMC memory's supported.
    •USB Card reader included!
    •No drivers or additional software needed.
    •Full Plug&Play.
    •Aluminium Cabinet prepared for Industrial conditions.
    If you need more info abut our product please contact us:
    www.floppyemulator.com
    [email protected]
    Dec 2003
    24220
    Quote Originally Posted by floppyemulator View Post
    Hi guys,
    This does not answer the purpose of the original question
    Will this replace the drive configuration used by Okuma, a regular off the shelf Floppy drive does not work.
    Al.
    Albert E.
    Jan 2010
    96
    Hello. If you are talking about the External floppy you have to have to load software make backups etc that plugs into the outside bottom of the electrical cabinet, no you cannot use any floppy. The reason is that Okuma has a special pin configuration for the interface cable. Its not the floppy its the cable pin setup. If there is a device that will hook up to an old Okuma i would love to see it. Sorry but this is the Okuma way. As far as the slightly newer machines, I.E. 700/7000 control and up, the floppy on the side of the operator panel can be changed out. It is just a standard floppy. Anything E series or the new P series control you use a USB stick. Boy isn't technology great. Hope this helps. By the way i have an external floppy for the old Okumas i may be able to be persuaded to get rid of since i dont go out on the road anymore for Okuma's. For a nominal fee of course, but not bad.
    Apr 2008
    211
    Hi guys,
    Bye! Aro/
    FlexiDriveS4
    Features
    •Full Plug&Play.
    [email protected]
    Hello Mr.emulator,
    Can a large program be drip fed through your gizmo?I have programs that are over 1 Gig. that I must break up in order to fit them on floppies.A big pain it is also having to mod the program to go to home position and then back to the last coordinate to pursue where it left off and so on.Also the possibility of errors with this method,not to mention the floppy expiring at any moment and then having to start over.
    Also as Al mentioned only specific floppy drives will work on the Okuma.
    In my case only a Teak can replace the original on my Dynapath Delta 40,50,60 controller.
    If I still have to break up programs,I don't see the point in a emulator over a new motherboard to drip feed directly from my pc. unlimited program size.
    USB uprades on Oskuma
    We have Floppy to USB upgrades for the Oskuma in stock...
    Floppy To USB Upgrades - Replace your 3 1/2 drive with a USB floppy simulator
    3 ½ floppy drive to USB flash drive reader upgrade
    Electronics Circuit Board Repairs and Design
    Jun 2008
    372
    Guys,
    Please remember that the control only sees the floppy drive as 1.44MB. If you change the Floppy drive to a USB emulator the control will still only see 1.44MB regardless of the size of the USB thumb drive inserted into the emulator.
    No. You need to have DNC-B or DNC DT/RT for drip feeding
    Jul 2010
    104
    Hey folks,
    A few months ago, I purchased a CNC/USB communication device from Shop Floor Automation. This is a great tool, hooks to a RS232 port and can transfer programs between ANY CNC and a USB flash drive and can even be used as a DNC. Setup was very simple and I have used this on Okuma controls, Fanucs, and Mitsubisis. It's worth checking out and very reasonably priced!
Page 1 of 2 12
  1. okuma lb15 spindle drive unit
    By TTT in forum Okuma
    Last Post: 02-03-2011, 03:49 PM
  2. OKUMA CROWN OSP 700L DRIVE UNIT
    By yorkshire grey in forum Servo Motors / Drives
    Last Post: 01-20-2010, 02:59 AM
  3. okuma LB15 spindle drive unit
    Last Post: 03-17-2008, 12:51 PM
  4. V2XT; Downloading from Floopy Disk ?
    By v488 in forum Bridgeport / Hardinge Mills
    Last Post: 01-02-2007, 06:25 AM
  5. boot floopy proble
    By bmfind in forum Commercial CNC Wood Routers
    Last Post: 03-22-2006, 12:28 AM
