587,925 active members*
3,481 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma captain l370mw setting sub side tools
    Nov 2022
    22
    As title says, I’m looking for help on setting tool offsets for the subspindle side of the turret, I have the e100l controller and a touch setter. I have my main spindle tooling 1-12, so I’m assuming I have to program the sub side 13-24. How do I use the touch setter but make the offset calibrate different than the selected tool?
    Nov 2022
    22
    Never mind I feel like a dummy now, I saw you just highlight the offset you want to cal and then run the tool setter and it fills whatever box you have highlighted
    Apr 2006
    825
    Re: Okuma captain l370mw setting sub side tools
    Quote Originally Posted by Cris_co View Post
    Don't feel like a dummy!
    Learning these machines is a life long pursuit, the day you think you know everything about the machine/controller is the day you start having major problems!
    I certainly felt very comfortable programming and using the machines I used, but there was always little bits of new stuff to learn, often from a totally unexpected direction.
    Keep asking questions, trying new stuff, Read the damn manuals and never stop learning.
    Cheers
    Brian.
  1. Okuma l370mw c axis issue
    By Cris_co in forum Okuma
    Last Post: 06-24-2023, 09:09 PM
  2. Okuma Captain L370M Prox Sensors
    By Chalkboard247 in forum Okuma
    Last Post: 02-08-2016, 02:13 PM
  3. Setting tools in Okuma with 5020L
    By SSracks in forum Okuma
    Last Post: 05-02-2014, 08:31 PM
  4. Okuma Captain L370M OSP-P100
    By SINUMERIKO in forum Okuma
    Last Post: 01-20-2012, 05:12 PM
  5. Setting up Tools - OKUMA OSP700L
    By hiatec in forum Okuma
    Last Post: 03-19-2008, 12:51 AM
