587,638 active members*
4,466 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Offering suggestions for Woodruff, radius slot milling for 1100 PCNC
Results 1 to 5 of 5
    Jul 2008
    81
    Hello Forum,
    I thought I would share my experience of CNC milling on my Tormach 1100 PCNC Series III some slots in a castellated steel nut. I bought a nice Harvey tools 1" woodruff cutter with .0625 r (.125) diam, Part # 937362. I was machining 4041 steel. I contacted Harvey and they were nice enough to help with some speeds and feeds as follows.
    SFM: 200, RPM 764, Chip Load: .00138 IPT, Feed: 6.33 IPM, DOC: full at .125" WOC .080. (3 passes)
    I tried these on a sample of 6061 to see how that would run but found it was very noisy. I felt I was getting a little chatter. Long story short I kept up with adjusting the speeds and feeds, # of passes and lead in and lead out until I got a good formula and ran the part in steel. The results were very good and so here is what I ended up with.
    SFM: 220, PRM: 850, Chip Load .00138, Feed 4.00 IMP, DOC: .125, WOC 0.020" with 8 passes.
    Hope this helps someone trying the same operation on their own.
    Nov 2012
    591
    Re: Offering suggestions for Woodruff, radius slot milling for 1100 PCNC
    Looks like a good recipe!
    My guess is that the low RPM is what caused the problems, as there's not enough power at those low RPMs. The original numbers might have been more appropriate for a geared drive, not a VFD?
    Jul 2008
    81
    Hello jwatte,
    Yes, I think so too. The 1100 does not really like to cut steel.
    By sharing my experiment hopefully someone else will not have to spend as much time as I did trying to figure it out. I keep a spread sheet of all
    my materials and speeds and feeds for reference. Once i get a recipe that works I note it there for future use.
    Thanks for sharing,
    Cismontguy.
    Nov 2007
    2151
    Quote Originally Posted by jwatte View Post
    I was guessing both low rpms and the .08 woc would be a problem. I set woc thin to win when testing.
    I break most tools because of woc. Last one I prepped and fixtured stock that was 1/2 wider then I specified in cam program. This resulted in near full woc on first pass down side of part. Mr bozoo went back to drawing board
    Nov 2005
    157
    Quote Originally Posted by cismontguy View Post
    Cismontguy.
    ???.....mine loves cutting steel! Though not necessarily with HSS form cutters
  1. Looking for Woodruff Cutter with Corner Radius
    By mgb1974 in forum MetalWork Discussion
    Last Post: 07-23-2020, 08:15 PM
  2. PCNC 1100 vs PCNC 770 (Is the 1100 worth it)
    By thunderdork in forum Tormach Personal CNC Mill
    Last Post: 09-21-2016, 08:43 PM
  3. Buying a PCNC 1100 Series 3 - Suggestions on My List
    By smokediver576 in forum Tormach Personal CNC Mill
    Last Post: 12-31-2014, 10:24 PM
  4. How do you get the spindle to turn on with a PCNC 1100 for "maual" milling?
    By SwampDonkey in forum Tormach Personal CNC Mill
    Last Post: 06-03-2013, 05:43 PM
  5. powermill and slot cutting with woodruff tool
    By krustykrab in forum Uncategorised CAM Discussion
    Last Post: 02-23-2006, 11:25 AM
