Just in case anyone is interested I will log my actual speeds & feeds.
The figures are based on my 1.5 horsepower 240 volt single phase mill/drill.
I don't push my machine but alter the feed until chatter is excessive then back off to limit said chatter.
I don't recommend any one else attemp these settings this is more for general information.
I will start with a corner rounding router bit not designed for milling but seems to work okay.
Rpm 1600
Feed rate 20mm/m
Coolant none
Cut full cut one pass
Diametre 22mm
Material Aluminium 6060 T5
Ji
