587,611 active members*
4,202 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Nubie G251 Assembly Question
Results 1 to 15 of 15
    Sep 2006
    247
    I just receive three brand spanking new G251. Now what?
    OK, I'm not really that lost. My real question is whether anyone has mounted these in an enclosure? Can anyone recommend a good enclosure and suggest a good layout? Did you use stand off screws? Where did you mount a fan? Basically, if anyone has a picture of their G251 set up with a parts list I would really appreciate it.
    How about a power supply? A BOB? Recommendations for these tiny little controllers?
    I am going to use this on a belt drive system, meaning I need low end torque that rarely will it spin fast. I intend to wire up some bi-polar motors 285oz in series, rated at about 2.1A/Phase. Will a 24v/6.3a power supply be enough? Should I get one rated at a higher a? Higher v?
    Thanks!
    Sep 2006
    247
    Nothing?!! Nobody has built a system with these controllers?
    How about Marris? Can you make recommendations of power supplies, BOB, enclosure and layout? Can you at least comment on whether the proposed power supply would be adequate?
    Thanks,
    Dec 2006
    277
    Can't help with your queries yet? but....
    I have the G251's and I am waiting for a 48volt/7.5amp switching supply for them. I am getting the Keling 285 Steppers for them and a BOB from them as well.
    Greolt has them working on his widgetmaster with a 24 volt supply so I guess it works with one and I did mention your post to him.
    Cheers, Bob
    http://www.ocm.com.au/wordpress/
    Dec 2007
    362
    Sorry I can;t help, still designing my setup.
    I have G250's which require a PCB assembly to mount them (similar to a G540). The power supply I have is a 48V 12A, steppers will be similar to Keling 270oz-in - same spec but different supplier.
    Regards
    Geoff
    Apr 2003
    312
    Be certain to read this ALERT...http://www.cnczone.com/forums/showthread.php?t=64964 and correct page one of your Gecko manual if you were sent a Rev 7, July 27, 2008 version.
    Senna
    Sep 2006
    247
    Quote Originally Posted by Senna View Post
    Senna
    Wow, thank you. I was sent the old manual. I would have been seriously bummed.
    Sep 2006
    247
    crocky and tumultbound,
    You both are going with 48v power supplies. Can I ask why? I notice, for example, that the probotix, xylotex, hobbycnc and keling kits all come with 24v power supplies. Also, crocky is going with 7.5 amps and turmultbound is going for 12 amps. Yet both are using the same motors. How do you know how many amps you need?
    Thanks,
    Dec 2006
    277
    Quote Originally Posted by rlrhett View Post
    Thanks,
    Hi rlrhett,
    I got the data from John at kelinginc.cnc and the drives I have bought are the set that he sells with the 540 and the power supply is the one recommended by Geckodrive
    http://www.kelinginc.net/KL23H276-28-4B.pdf has the specs for my motors.
    PS. Just read the message about connections and I have the old doco too!
    Cheers, Bob
    35538
    The reason is that the Xylotex and Probotix are limited to about 30 V, and 24V is the most common size close to 30V.
    Thanks,
    2/3 of the motors rated current. For example, you need 2 amps for a 3 amp motor. 2/3 x 3 = 2 amps.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2007
    362
    Thanks,
    The G250's are rated for 50V hence the 48V supply. The reason for the 12 A rating is that was the only one available from my supplier.
    Regards
    Geoff
    Sep 2006
    247
    Of each motor, or all motors? For example, if I have three motors rated at 2.1amps, do I need a power supply 4.2 amps?
    Thanks!
    35538
    I come up with 4.4, but yes, in the example I gave before, it was 2 amps per motor.
    Gerry
    Dec 2006
    277
    How is the construction going? any pictures?
    I am still waiting for a BOB so it will be a while yet.....
    Cheers, Bob
    Sep 2008
    16
    Smile
    ger21,
    How do you come up with 4.4
    Jerkyboy
    35538
    Quote Originally Posted by JerkyBoy View Post
    ger21,
    Jerkyboy
    Not sure, because I'm getting 4.2 today. But I used a calculator and double checked, and somehow got 4.4 at least twice.
    Gerry
  1. Need help with assembly please
    By dpark1 in forum Solidworks
    Last Post: 07-26-2008, 03:43 PM
  2. Question about hole sizes on Bearing Slide Assembly
    By kevperro in forum Joes CNC Model 2006
    Last Post: 04-17-2008, 12:33 AM
  3. DIY Nubie questions. learning as i go.
    By Revtech in forum DIY CNC Router Table Machines
    Last Post: 05-30-2006, 02:07 AM
  4. Cnchobby Board Assembly Question
    By jason_ices in forum Hobbycnc (Products)
    Last Post: 06-18-2005, 09:45 AM
  5. Nubie needs help
    By SPEEDRE in forum CNC Machine Related Electronics
    Last Post: 06-08-2005, 09:28 PM
