587,913 active members*
4,158 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Not another single phase 3 phase question......
Results 1 to 6 of 6
    May 2024
    2
    Guys,
    For the purpose of my business, I will need a CNC that can cut full 8x4 sheets
    I have been looking at the blue elephant 1325 with a 3KW spindle rated at 3 phase. I understand that there is a VFD fitted in the control box. If these VFDs take single phase and convert it to three phase, for what reason does the machine need 3 phase? Possibly the axis motors although I don't think this particular model comes with servo motors. It does not have a vacuum bed or extraction.
    This poses a challenge as I only have single phase at my house.
    I have done lots or reading around the subject but just not grasping the theory behind it.
    Looking for some advice. Have done lots of reading about static, rotary phase converters.
    TIA
    Nov 2013
    4554
    Re: Not another single phase 3 phase question......
    That is too simplistic. Yes, a VFD can take single phase input and then generate three phase for an induction motor, but you'd be extremely disappointed if you expect it to drive some regular three phase load.
    The output of the VFD is sinusoidally PMW modulated DC, and it does after a fashion replicate three phase.
    The spindle is almost certainly a three phase asynchronous spindle and speed control is gained by applying a 'varying frequency three phase', ie the output of the VFD.
    Craig
    Apr 2018
    136
    Quote Originally Posted by ap90 View Post
    Guys,
    It looks to me as though they offer at least some machines that are capable of utilizing single phase 220/240v if thats what you want:
    Working voltage 220V 1PH/3PH 50HZ/60HZ 380V 3PH 50HZ/ 60HZ
    Original source:https://www.elephant-cnc.com/pro/the...ar-atc-router/
    I suggest clarifying your electrical requirements with Blue Elephant.
    Apr 2022
    140
    3 phase as more efficient than single phase and one still wants a soft start and control RPM that is when VFD comes to play.
    You can request a single phase setup if you don’t have 3 phase but it cost you more to operate as you have to derate horsepower of the motors.
    from cnc choice to think .
    1325 3kw spindle ,stepper motor ,dsp etc 220v1 phase ok .
    3kw dust collector ,220v1 phase ok.
    but if you only have 220v1 phase , there is only 2.2kw vacuum pump can work with 220v1 . 5.5kw 7.5kw vacuum pump need 3 phase power .
    You can also add one pcs roller hold on table to hold wood .
    Roller hold wood without vacuum pump details show on ATC cnc router
    https://youtu.be/zkhIYKSgou0
    if you want more info ,you can contact with me by [email protected] or whatsapp +8618560201508
    Nov 2011
    265
    Hello sir, we are Blue Elephant CNC. Please contact us.
    Contact Information:
    Email: [email protected]
    Whatsapp/mobile: +86-15064026772
    We will listen carefully to your specific needs and provide a reasonable solution.
    E-mail: [email protected] Web: www.elephant-cnc.com
    --------------Jinan Blue Elephant CNC Machinery Co., Ltd-------------
  1. Replies: 29
    Last Post: 02-12-2022, 09:20 PM
  2. Lincoln Idealarc R3S-325 3 phase to single phase
    By minipower in forum Welding Brazing Soldering Sealing
    Last Post: 07-29-2021, 04:23 AM
  3. Robodrill 7.5hp spindle. Single Phase Power input No Rotary Phase convetor doable?
    By whiteriver in forum CNC Machine Related Electronics
    Last Post: 01-05-2017, 09:01 PM
  4. Replies: 2
    Last Post: 09-24-2015, 07:04 PM
  5. Replies: 12
    Last Post: 10-13-2009, 03:53 AM
