587,089 active members*
2,782 visitors online*
Thread: No Motion
    Jul 2004
    148
    No Motion
    Here is the situation. I'm using turbo cnc with xylotex driver.Computer is a amd k6 "processor 2" 3d now, 450 mhz. 186 mbites. I grounded all three enab to ground pin on molex. Not sure if thats right, tried them ungrounded also. I've just got one motor hooked up right now on the x axis. 5v logic is from a tie in off of the cd rom. The motor does have power indicated from a humm or soft whislte sound but no motion when jogging or anything. The questions I am now asking are: should I have grounded enab for xyz? Could the parallel cable be "not wired all the way"? Is there a "uS" (pule width) setting or other not set correctly. Tried many configurations of max start herz and such. Step is set positive high. Could I have one of those computers that just won't work with program? Also for some reason files for turbo cnc cannot be copied off of floppy disk. I tried two different disk drives. I get a message of unable to read . Any help. Boy I'm beat and its probably somethin simple as is the story of my life. Thanks anyone
    Sep 2003
    66
    Flute Head,
    What kind of board is it? It will be worth you while to register with the Xylotex Support board:
    http://groups.yahoo.com/group/Xylotex
    Also, if you e-mail Jeff directly, he has been very fast at responding to my e-mails.
    Hope This Helps,
    George
    35538
    Are the motors locking with power applied? If so, check the parallel port address in TurboCNC.
    If the Motors lock up, then it's a TurboCNC issue, not a Xylotex issue.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Linear Motion FAQ
    By Cutters Cove in forum DIY CNC Router Table Machines
    Last Post: 03-08-2018, 02:14 AM
  2. Series 2 BOSS 6 Axis motion problem
    By craig96us in forum Bridgeport / Hardinge Mills
    Last Post: 01-14-2006, 06:06 PM
  3. TurboCNC with PC Motion Card??
    By Al_The_Man in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-06-2005, 10:41 PM
  4. Kerk Motion Leadscrew Possible Problem
    By ThomasAlva in forum Mechanical Calculations/Engineering Design
    Last Post: 01-27-2005, 07:17 PM
  5. MaxNC motion kit for Sieg X3 mill?
    By replicapro in forum CNC Machine Related Electronics
    Last Post: 06-16-2004, 06:24 AM
