587,158 active members*
3,061 visitors online*
IndustryArena Forum > CAM Software > MadCAM > No cuts seen in simulator with MC 6 SR4
Results 1 to 5 of 5
    Dec 2011
    97
    Using a 3 axis machine and a pocket cut, when I run the simulator, the tool moves correctly but the model does not show any of the cuts. Thanks for any help.
    Dec 2012
    12
    Re: No cuts seen in simulator with MC 6 SR4
    I have the same issue, no cuts shown on the sim. I've got MC 5.0 with Rhino 5.0.
    My machine is defined as "3-axis" in the options.
    Any help appreciated.
    Dec 2011
    97
    Any updates about this?
    Mar 2004
    1661
    I am not at my CAM computer at the moment, but I am pretty sure I did pocketing the other day without any problems in the sim. I can check later.
    Dec 2011
    97
    I've discovered my problem. With the "Draw model" option checked, I did not see that material was removed because the model was always shown. So user error.
    But it does make me wonder when it is useful to have "Draw model" checked.
  1. New Tube but only cuts for 30second then laser cuts out
    By JBxrayman in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-11-2016, 05:57 PM
  2. Does tool life vary with interrupted cuts to continuous cuts
    By acejunker in forum MetalWork Discussion
    Last Post: 08-08-2014, 02:34 AM
  3. Replies: 2
    Last Post: 12-28-2011, 11:44 AM
  4. frustration....plasma cuts off during cuts any ideas?
    By gpnjuice in forum Waterjet General Topics
    Last Post: 11-19-2007, 01:45 AM
  5. which cnc package cuts 2D parts with least extraneous cuts?
    By mbwittig in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-07-2007, 12:29 AM
