I love my NM-200 and have put it though hundreds of hours of milling thus far. It works great and is clearly limited by my poor machining skills. With that said, it has a few quirks I wanted to ask about to see if there is a fix as they can be annoying.
1) When the coolant relay turns on, it blanks out the computer monitor for a second. It looks like it's drawing too much power and causing the monitor to reset. Kinda weird, been doing it for months so it's not a huge deal I was just curious about it.
2) When I leave the machine idle and not running a program for a while it stops taking input. After something like 30-60 minutes of just sitting there I can no longer jog the axis' any more. It's odd though as a long running program has no trouble. This is VERY anoying as it's screwed up a few jobs due to forcing me to close and re-open Mach to get back to working again due to a long delay between tool changes. This causes me to need to re-home and re-touch off the work - losing the little accuracy I already had.
3) Finally, on several occasions, I've had the spindle just stop as it was bogging down a bit. It's more frequent at lower speeds but I've had it once at high speeds. The machine was doing some work, but I don't run anything larger than 3/8" drill bits and 1/4" end mills so it's not as if I was hogging or anything like it. The spindle does seem to bog down an odd amount when I start a cut which seems kinda funny to me too. I'm guessing this is the dreaded "spindle problem" people have talked about on the forum and supposedly this didn't occur to too many machines? It's pretty frustrating as it causes me to break bits via unattended crashes but it's also pretty rare. I think it's rare for me as I usually do all my cutting at max RPMs.
4) I get a message in Mach - often but not always - about "simulating spindle speed" due to a lack of feedback. I have no idea what this means.
5) Just once I had the machine stop running g-code right in the middle of a problem. No error, no warning, nothing. It just stopped running code and I had to close and re-open Mach to fix it. Never happened before or since. It still makes me nervous though.
I'd say that about 95% of the time my jobs finish without problems and so I just don't concern myself with it that much but as I try and become a better machinist I'd like to learn more about how to fix these things and what causes them. Thanks!
-Mike
