587,675 active members*
3,837 visitors online*
Results 1 to 2 of 2
    6855
    NextEngine 3D Scanner
    Any opinions on this NextEngine 3D Scanner?
    May 2007
    3
    not bad...
    So after buying and using the 1st gen NextEngine... I can say the upgrade to the Pro was definitely worth it. I think it's a good entry level scanner, but if you are looking for really fine detail work, this may not cut it...
    the laser tends to be noisy in it's data capturing. So surface prep and ambient light control IMO are a must.
    The automation of it's turntable is great.
    So, figure out what you need to scan. Small - medium sized objects with smooth not too detailed surfaces??? great
    small detailed intricate works: not bad, but could be much better
  1. NextEngine HD 3d scanner... the verdict?
    By drwhen in forum 3D Printing / Scanning Software and Hardware
    Last Post: 02-14-2019, 10:57 AM
  2. NextEngine 3D scanner- export to web help
    By krisbfunk in forum 3D Printing / Scanning Software and Hardware
    Last Post: 09-28-2011, 02:48 AM
  3. NextEngine 3D Scanner used for a tool presetter??
    By l u k e in forum 3D Printing / Scanning Software and Hardware
    Last Post: 08-21-2010, 01:48 AM
  4. NextEngine 3D scanner info needed?
    By myxpykalix in forum 3D Printing / Scanning Software and Hardware
    Last Post: 07-31-2008, 11:54 PM
  5. Anyone use NextEngine scanner for woodworking?
    Last Post: 10-15-2007, 01:01 PM
