587,925 active members*
3,711 visitors online*
Results 1 to 20 of 20
    Feb 2005
    234
    Question Newbie questions ?
    I would like to build CNC Router about 1 meter by 1,5 Meter size with 50cm Zdepth cutting, Mostly cuts wood and Epoxy/fiberglass.
    Precicion / backlash about 0.1mm required.
    questions:
    1. Can I use Stepper motor ? what size ? is Servo better ? how ?
    2. What is bearing/leadscrew required for this ? minimum diameter ? what type ?
    3. Does Gecko drive or Hobbycnc drive enough for this accuracy I need?
    4. http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
    what about this item on ebay ? too small or too much ?
    5. can I ask more ? later...
    rud
    Feb 2005
    44
    1 yes. 275oz/in at least or set-up with gear reduction.
    2 doesn't matter. You need to figure out how fast you want to cut/jog/etc... You already know that ballscrews are the most precise...so, go with them.
    3. yes.
    4 looks good to me...maybe I'll out bid you ...LOL
    5. I guess, these question are easily answered if you search and read a little bit.
    Mar 2005
    11
    Hello Calico,
    I am presently running my machine with direct drive 5mm pitch ballscrews from Techno-Isel. My machine is almost exactly what you describe. In my experience, my machine will max out (stall) at approx. 125 inches per minute. It presently has an accuracy of .00098" at full step. Here is the quick math for this...
    5mm screw pitch / 200 motor steps = .025mm... .025mm * .03937 = .00098"
    This is a tad bit overkill due to the fact that I run a plasma torch or a Porter Cable 3.25 HP router on the toolpost. I am re-designing my machine for a 4:1 reduction with belts. I am way excited with the prelim. drawings and speeds. With a 20mm total pitch, I feel it will be a perfect mix between speed and accuracy. I would be more than happy to send you my dwg file so you can check it out. It is a solid model, therefore you can look at it from any direction (the ONLY way to verify any machine collisions). If you have a way of viewing a dwg, let me know...you won't be sorry! This post is based on an actual working machine, already built and proven, with the exception of the belt reduction. I can provide you with actual part numbers for all of the parts needed. It is currently running Techno-Isel screws and extrusions, Hiwin linear slides, Gecko drives, Mycom/Nyden steppers, and Mach2 software. The machine extents are X=49", Y=98", Z=9". Hopefully all of my ramblings have not confused you in your quest! By the way, Techno-Isel does have 20mm screws...perfect for your application...and mine! Hindsight's 20/20!!!
    Good luck and happy machining...
    C
    Jan 2005
    1695
    Kevlar, can you tell me what the linear slides cost?
    Mar 2005
    11
    H500,
    It's been a while since I bought mine. I'll have to look it up for you. In the meantime, I do recall speaking to the Hiwin rep out of Los Angeles, I believe. His name escapes me now, but if you look on their site, I think you can find an 800 number for them. As for the linear slides themselves, when I was designing my machine...(5 years and 2 wives in the making!)..., I researched virtually every manufacturer out there, and none of them even came close to Hiwin, in the bang-for-the-buck category. I have been completely satisfied with mine, as I am certain you will be too. If I can assist you in any way, please let me know. I am more than happy to help out a fellow DIY'er. By the way, the linear slides I am running are the LGH-25CA series...more than strong enough for even the most demanding aluminum milling operations.
    Happy machining
    C
    Jun 2004
    131
    Kevlar,
    I want to understand your math. You say you would like to use a 4:1 reduction gearing. Does this mean that you will have 1/4 the speed and 4 times the torque, or is it the other way around? If you go from 5 mm pitch to 20 mm pitch is seems your speed goes up by 4 and your torque is decreased by four.
    I am currently running 200 oz/inch motors on a 18tpi lead screw (about 1.5 mm pitch I think) and it is too slow. I am thinking of going to a 3/8-10 which is a pitch of about 2.5 mm pitch, half of what you have today. To complicate comparison between our machines I am using ACME precision lead screws instead of ball screws which are about 1/3 as effeicent as yours (eat up a lot of power).
    Anyway I wanted to understand what you considered the "perfect combination of speed and accuracy" was before I go off and invest in some more lead screws.
    Thanks,
    Greg
    35538
    Greg, you might want to try the 1/2-8 2 start acme from MSC. It's only ~$25 for 6 ft, so you won't be throwing a lot of money away. 4 turns per inch, with around 65% efficiency.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2005
    11
    GREGMARY,
    Yes, you are absolutely correct in your assesment of the speed/torque trade-off. As I expressed in my previous post, my machine currently stalls (runs out of torque) at 125-150 inches per minute...way too low, wouldn't you agree? Therefore, with the sacrifice of "human hair" accuracy, I will allow the motors to spin well within their "torque bandwidth", with reasonable feedrates of 250 IPM. That being said, you are correct that I will have a theoretical 1/4 torque, but, when I had no torque left at an acceptable feedrate to begin with, I think I'm in a win-win situation. I must admit that I have substantially more torque on tap than I gather you do. My X is 950 oz in, Y is 1450 oz in, Z is 490 oz in. With a 200 oz in motor like you have, I can certainly see your concern for my design...my bad, I should have provided all of the relevant info in my first post. Thanks for the question, I hope I didn't confuse matters any further.
    Happy machining...
    C
    Mar 2005
    11
    GREGMARY,
    Sorry for the back to back posts, but I did neglect to mention that motor torque needed is "directly" proportional to what your intended machining plans are, as well as the "dead weight" of your machine itself. If you are doing non-contact machining, you could probably get away with a smaller motor. I do both, so I am sure many people would agree that my gantry is way over-cooked for NC plasma cutting, and just about right for contact machining with a heavy Porter Cable on board. Hope I helped.
    Happy machining...
    C
    Jun 2004
    131
    Kevlar,
    Holy smokes, 1450 oz in on Y! What are you using? A Briggs and Straton lawnmowing engine?
    I was poking around on ebay today and found a couple of "buy it now" ballscrews, one for my x and one for my z. Kind of an impulse buy you might say. So I hope to get more power to my cutter--contact machining as you say. It is always fun to get things in the mail.
    Greg
    Mar 2005
    11
    Hey Greg,
    Yep, over-cooked eh! Check out clickautomation.com for awesome deals on steppers and such. Best source I have found so far. Good luck on the Ebay items.
    Happy machining...
    C
    Feb 2005
    234
    Kevlar,
    thanyou for the reply,
    yes I use Solidworks if I can explore your CNCdrawing on that.
    The difference between your's and my plan is the Z travel, I need about 60cm travel.
    send me your file to [email protected]
    regards
    ruddy
    Mar 2005
    11
    Ruddy,
    We'll do. Can you give me a day or so, as I have not designed my Y axis screw mounts. With my belt reduction design, I have switched it from a rotating screw/fixed nut to a rotating nut/fixed screw. After I design the mounts, I will need to bind all of my xrefs in the model. I will also shoot you some photos of the current NC table, so you can see the "old" setup. I will also name the layers according to the actual part numbers and manufacturers, so you can easily check part numbers and/or costs. I am most pleased to offer my humble experiences with you all, and help in any way I can...after all, if you could afford a $300,000 Haas, you wouldn't be in this forum
    Stay tuned, model is on the way. On that note, am I ok to send about 3 meg to ya?
    Happy machining...
    C
    Feb 2005
    234
    Kevlar,
    yes 10Mb maximum gmail accept at a time.
    yes I can wait 1day no problem.
    take your time.
    rud
    Mar 2005
    11
    Hello all,
    Here's a quick shot of my model for my machine I currently have. I will post the DWG in the downloads/wood routers section. The model is under development, therefore it does not display some minor fasteners. Please post a reply if you need a different format, or a simple 2D working drawing. Thanks to all who inquired.
    Happy machining....
    C
    Mar 2005
    11
    Sorry guys,
    The upload failed... Try this link to grab it:
    www.trussconnectors.com/lse-gantry.zip
    Hope it works!
    I'll check in a bit. Thanks for your patience.
    Happy machining...
    C
    Feb 2005
    234
    do you have different format like solid works ?
    can you cut alumunium/metal with that toy ?
    what's the size of the motors ? stepper ? what drive r u using ?
    thx
    rud
    Mar 2005
    11
    Rud,
    I don't think I can help you with the Solidworks format, for fear I'll screw the drawing up. The Solidworks version I have is 2005, and it's got a DWG "translator" built in. Every time I launch it, I seem to get a little frustrated with the results, and I wind up going back to Mechanical Desktop. I probably just can't get my brain to think like Solidworks. If you can tell me how to convert it on my end, I'de be happy to do it for you. As for your second question, I assume you saying "cut aluminum/metal", you are refering to milling operations? If so, the answer is yes and no. Yes, being the "softer" alloys (mainly aluminum, which I have milled) and no, being the "harder" alloys such as steel (note, I say this because I have not attempded it...yet). As for your third question, I'll give it to you in a drill-down list...here goes:
    1. Pentium 3/500 running Windows 2000 with Mach2 controller software
    2. Gecko G201 drives on all axis, powered by a Copley 21980 supply (75vdc@15A)
    3. Mycom/Nyden steppers: X= PS4913A-01, Y= PF4913A-05, Z= PF468A-02
    4. Techno-Isel 5mm pitch X 16mm Diameter ballscrews on all axis
    5. Hiwin LGH25CA guideways on all axis
    6. Techno-Isel extrusions for X gantry and Z toolpost
    7. 2 X 3 X .134 tubing table bed
    In looking at the specs for the steppers I am using, I over-estimated the torque that I have available, although it is more than enough for this machine. If I left any questions unanswered, please let me know.
    Happy machining...
    C
    Feb 2005
    234
    can you just send me your CNC photosss
    the detail leadscrew, ballscrew, motor, any thing I want to know.
    then I'll ask you questions.
    thanks
    alot man
    ruddy
    Mar 2005
    11
    Ruddy,
    Last night, I started exporting all of the parts that need to be machined, out of the 3d model and into 2d DXF files. I am about halfway there, so if you can hang in there, I will be able to send you all of these drawings. I will keep you posted on the progress. I can also send you digital stills of the machine in it's present design, but it will reflect "revision 1" of the machine, which is direct-driven by the steppers.
    Happy machining...
    C
  1. newbie questions about software/hardware
    By cowanrg in forum Uncategorised MetalWorking Machines
    Last Post: 11-30-2005, 11:45 AM
  2. Newbie Questions
    By Todd Price in forum DIY CNC Router Table Machines
    Last Post: 04-17-2005, 02:31 AM
  3. Autocad user has newbie SW/CNC questions
    By cadesignr in forum Solidworks
    Last Post: 02-11-2005, 08:19 PM
  4. Newbie CAM questions
    By WoodSnarfer in forum Uncategorised CAM Discussion
    Last Post: 11-12-2004, 02:15 PM
  5. Newbie questions
    By NeoMiller in forum Uncategorised CAM Discussion
    Last Post: 11-09-2003, 02:39 AM
