Just got my Taig/xylotex package up and running and am a bit confused as to which way the axises (?) need to go.
Which way does -X go? left or right? Do I home on the left end of the table or the right? What about the Y axis?
Looking thru some G-code I see negitive numbers. Will that mean I need to zero on the middle of the table?
Also.
How do I work the backlash? I've set it to 0.004" and turned it on in Mach2 but when I draw a circle with a pen clamped to the head the ends don't exactly meet. They miss by a small amount.
I've read the manual and have it open as I've worked with the unit. Still a little confused on the backlash tho.
James
