OK here goes. I have and idea for a CNC router using a 2-1/2 hp router. Cutting area X=32" Y=20" Z=6". I have 2 ea hardened to RC60 1-1/4" rods with thompson linear ball bearings for the X axis I plan to use the rods unsupported in the middle and anchored on the ends. I plan to use 3/4" hardened steel rods for the Y axis with Thompson linear ball bearings. I will use 1/2" hardened steel rods for the Z axis with Thompson linear bearings. I have a good source for new Thompson bearings. I was going to use 1/2" aluminum plate for the movable gantry sides. Plan on using 5/8" ball screws for all drives. I cannot decide on stepper motors, 269ozin or 640ozin both with Gecko drives. Please let me know what you think. My main concern is will the X axis be rigid enough W/O support in the middle. I plan to put 4 bearings on the gantry (2 per side) on a 12" wide gantry.
