587,395 active members*
3,513 visitors online*
Results 1 to 4 of 4
    Nov 2007
    25
    Newbie Needs Help
    Hello everyone. I am looking for some advice/guidance with a new (old) amchine our company just received. It is our first CNC machine, a Dyna Mechtronics 4800 with a Meldas 520 control. My issue is, what communication software is good to use?
    We use Solidworks to design, SolidCAM to program and spit g-code. I spoke with a guy at Mitsubishi and he said they recommend ProComm, which I found to be a discontinued software. Any others that work well, and have a relatively low learning curve?
    May 2008
    2
    Have you heard of a software call Preditor Editor? You can edit your program and you can also use it to send to the machine thru the RS232 port
    Nov 2007
    25
    I had seen it is passing, but was unsure of which one to choose. They have a few on the site, but the "Predator CNC Editor" is the version you recommend?
    I wouldn't be doing any actual editing of the code, just basic transmission and checks on the part as the machine is being run.
    May 2008
    16
    Vega DATA-View supports USB and RS-232/422 serial transfers, shows the
    machine animation during file transfers, and supports point and click file mid-starts.
    Free fully functional demo copy available at www.vegacnc.com
  1. newbie c.n.c.er
    By Kmanco in forum Torchmate
    Last Post: 02-11-2008, 05:28 PM
  2. Newbie here to ask about what to go for?
    By dwarfogre in forum DIY CNC Router Table Machines
    Last Post: 12-11-2007, 12:14 PM
  3. newbie to cnc!
    By spross86 in forum Mach Mill
    Last Post: 09-13-2007, 03:52 AM
  4. newbie to cnc
    By adrobbi in forum Benchtop Machines
    Last Post: 06-08-2007, 08:18 AM
  5. Newbie Needs help!
    By gmarquez04 in forum CNC Machine Related Electronics
    Last Post: 10-27-2004, 01:05 AM
