Hu,
I notice in your drawing the bearings are still back-to-back...
While this is gonna be okay for a small mill like this thread is discussing; remember the spaced lower bearings if ya wanna "do it right" and get a MUCH stiffer spindle. I agree that labyrinth seals are the way to go.
Now, as for that pressure: It's not ridiculous, but it does take some push. There is a QC retrofit for BP mills(R8), that uses the operator as the spring "compressor". Tool change is done by pushing the quill lever in reverse(up) so that the top of the spindle meets an added fixed stop which compresses the spring, and releases the tool. My point in describing this is to show that the force required is not "tons"... Think about the multiplying effects of the Balls on the retention flare.
I was looking at a Haas VMC service manual while writing the last post, and VMC's don't have quills...
Certainly in the case of a retrofit to a quill equipped machine, you'd want to be mindful of the pressure downwards during a toolchange. possible you could have the mount for the toolchange piston ride ON the quill too; which would confine the force to the spindle bearings only. Or try to use the "upward" technique described above.
Assuming full ATC capability, you could incorporate a stop which comes in with the tool carousel shuttle. then the shuttle would need to resist the force, not the spindle/quill.
Typical cnc tapers are non-locking types. You don't want that tool stuck during an -attempted- toolchange!
Hope this helps,
Ballendo
Originally posted by HuFlungDung
Thanks for that info, Ballendo. It must take a fair bit of pressure to overcome that retention spring, would it not? So is there actually enough tension in the retention knob system that the tapers want to lock a little bit, like a regular NMTB taper with a drawbolt?
Seems like it would or could be quite a push to release, so a person would have to be mindful of creating the Z axis quillbox with adequate strength for this purpose.
