Background:
I worked as a machinist years ago (not an operator, but a crank turning, DRO reading old-school machinist) on full sized equipment cutting mostly stainless and plastics, all dry. I play at it still at home and have a Grizzly 12x37" 2hp lathe that just has a DRO, and a modified tail stock for "speed drilling". I also have a Grizzly G1006 2hp Mill drill that I converted to ball screws and Servo CNC with a 4 axis Gecko based controller from Dan Mauch.
Where I am now:
I'm making parts for Radio control airplanes/tanks/miniature I/C engines and some custom race car stuff, and MOST of the parts are very small and aluminum. Many of the mill parts are less than a 4x4" and much of that less than .250 thick. I tend to cut everything with cutters .250 and under. On the lathe, much of it is less than .500 diameter and less than 6" long (I do deep drilling on the lathe though). I still think like a production machinist, and get a little frustrated at how long it takes me to make parts with my slow machines. I think both the lathe and mill drill are overkill and the spindle speeds are too slow (The Mill doesn't seem that rigid anyway). I want to CNC the lathe, but don't want to spend the money for the bigger parts and capacity I will rarely use, and still have a slow machine that I can't really use manually anymore
So, here's the questions:
I want to have better accuracy, and higher speed for both lathe and mill. Both have to be servo since I already have a good controller. Given my desire to cut much faster, and since I'm cutting small aluminum pieces mostly, do I:
1. Lathe - Convert what I have to CNC, or buy a small lathe and convert that? I want to do cnc threading too. Ideally, I'd like a little slant bed machine with both gang tooling AND a tail stock - I don't plan to use a tool post, as the same 3 or so tools will cover almost everything I do. It would be pure CNC, so I'd toss most but the bed, tailstock and motor. Can those mini lathes do real work, like perhaps the MICROLUX 7x16 MINI LATHE, Seig C4 etc, or are they going to be just too floppy/low quality? Any small ones that spin faster? Bore hole size might be the limiting factor. 3/4" is kind of the minimum I think, and bigger is better.
2. Mill - Is there something small yet sturdy out there with a high speed spindle, or just build my own machine to do just high speed machining? I want it sturdy, and the column doesn't need to tilt. It could probably just have the motor move up and down rather than having a quill, and doesn't have to have a huge envelope, but it needs to spin a 1/8" and smaller cutter at efficient speeds. I'd rather have something smaller, faster and more precise than I have now so I can really whip out the little parts. Many of my parts are about the size of a dime or smaller and .125 thick that I cut out of 1/2 wide by .125 6061. I do lots of "buried cut" profiling, and a bit of drilling. The Tormach PCNC 770 which seems decent, but a bit too much dough for my budget - maybe if I could get it without the controller - something like that a tad smaller?
Thoughts, Links, Contacts? I can probably make most stuff, but if the price is right, would rather buy at least pieces rather than make them. Ready made CNC stuff doesn't seem that great a value, and the small stuff is usually stepper without real ballscrews anyway.
Here's an example of some of the stuff I'm making: This is a 1/13 scale (about 6" x 6" in size) functioning retractable landing gear for a R/C WWII bomber (a He-111 in this case).
