587,784 active members*
2,492 visitors online*
Results 1 to 6 of 6
    Jan 2011
    12
    New Grizzly G0619
    Hey guys,
    I think I have read so much I am going blind!! So much good information here from everyone!!!
    Anyway, I have this new G0619 mill on the way from Grizzly and I want to CNC it right away. I need to purchase the electronics and the CNC Fusion kit. I am looking at the following and would appreciate any advice.
    From Keling:
    G540 4 axis package (one G540 + oneNEMA 34 KL34H295-43-8B, 906
    oz-in +Three NEMA 23 KL23H2100-35-4B (1/4” Dual shaft with a
    flat) 381 oz-in + one KL-600-48 48V/12.5A 115V /230V
    power supply): $630.95
    I know Keling makes a 3 axis kit just for the X3 but this kit seems more substantial, and I want the 4th axis.
    From CNC Fusion:
    Kit #4 or Deluxe. (If I can get away with kit #4 it would be nice to save the coin).
    My questions:
    1. Will it work with these components?
    2. How well will it work (subjective I know....)?
    3. Other recommendations?
    I want to use the mill mostly for gun work (milling receivers such as AR15, 1911), boat stuff, and anything my wife makes me do for her in trade! (nuts)
    I have a Shark Pro CNC which uses NCPOD, NEMA 23 3 axis, Vectric software 3D Cut, Vcarve Pro v6, and Photo Vcarve. I figured I can reuse the Vectric software. So I am familiar with CNC, but this will be my first mill. So I will be a garage NOOB mill guy. :drowning:
    I will probably run EMC2 or Mach 3 ( Any recommendations appreciated ).
    Thanks everyone!
    Jimmy
    Nov 2009
    724
    Sounds like you are off to a good start!!!
    I personally would spend the extra coin on the deluxe kit, which I did.
    make sure you get the CR option with your kit from cncfusion.
    I have had mine converted for a while now and am loving every minute of it, if I can affer a little advice it would be to spend some time on the ways and gibs especially the Z with a little work these can be very capable little mills
    good luck!
    JTCUSTOMS
    Apr 2011
    0
    You got your mill yet? I'm curious how much the heaviest part weighs.
    Mar 2008
    3655
    Quote Originally Posted by Bmr4life View Post
    The SX3 breaks down into 5 main parts:
    1: Head. (Still connected to electronics tower}
    2: Column
    3: Saddle
    4:table
    5: Base.
    The head/motor weighs the most. About 90 pounds.
    I took mine apart, built the stand and then assembled it onto the stand: Base, Column, Saddle, Table. Crank down the head mount, put blocks on the table, Set the head on the blocks and install head to rotary mount. Quite manageble by one person.
    CR.
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
    Apr 2011
    0
    Oh, that's definitely not that bad.
    Mar 2008
    3655
    Teardown pics:
    Page 28
    CR.
  1. Grizzly G0619 Sx3 spindle bearings replacement
    By flashbang in forum Benchtop Machines
    Last Post: 03-20-2013, 05:19 PM
  2. New Grizzly G0619 Arrives
    By magma-joe in forum Benchtop Machines
    Last Post: 07-28-2010, 02:37 PM
  3. GRIZZLY G0619 IN THE ALBQUERQUE AREA?
    By ricksigler in forum Want To Buy...Need help!
    Last Post: 06-23-2009, 12:02 AM
  4. Seig SX3 = Grizzly G0619 = Shop Fox M1111
    By blacksmith99 in forum Benchtop Machines
    Last Post: 01-04-2008, 12:46 AM
  5. Any opinions on the Grizzly g4016 lathe or other Grizzly lathes?
    By DublD in forum Uncategorised MetalWorking Machines
    Last Post: 11-26-2006, 07:23 PM
