Hi all friends,
below is our LC1390 laser cutting machine difference from normal 1390:
1. Four sides material pass through .feeding height 10CM
2. Red dot pointer light (laser tube or laser head both can install)
3 .Up &down lifting height 20CM, with the up-lower limit switch
4 It can split form machine body and machines base for taking into 80cm height gate/door
5. Cooling chiller & air compressor put behind the machine body does not take up space
6. Air Fan controlled by separate switch
7. Installing AC contactor to solve the 110V voltage with high current problem
8. Auto Focus
9. The focal length can be switched from 22.5 to 5 inches
10. The new type laser head& new type mirror housing with a center hole debugging
11. RECI Laser tube socket
12. High-speed rail & linear guide two kinds rail installed
13. Motor with coupling middle driving
14. Can put two -layers packed wood case into containers
15.Better Suction, with a switch can turn off any one of them
16. Ruida & Leetro control card both can install
17. Knives-table or honeycomb table with funnel
18.Optical target can debug all mirror housing and center of laser head
19. Lifting platform with a ruler diagonally put on
20. Machine-front part can Remove out the lengthen drawer Of the funnel, high-end grip
21. Control cabinet and Laser power supply separate (considering laser tube broken then water directly into the laser power problems)
22. All wires traces hiding
23. Can automatically switch inflatable
24. American powder spray (to avoid collision fade)
25. Machine large cover with four hinges, anti-fracture
26. All switch (key switch, emergency stop switch, USB port, LCD control panel, ammeter etc all install on the upper-right part of machine body)
27 The total machine height: 1050mm /machine length 1800mm /width 1400mm
Attachment 301856Attachment 301858Attachment 301860Attachment 301862Attachment 301864Attachment 301864
this is updated 1390 laser cutting mahciune with low price,
skype:wkquiven
[email protected]
whatsApp:8615698041856
