Originally Posted by
LeeWay
I didn't really have a problem with the first beam design being sufficient to cut aluminum. My main issue was with fabricating that beam. It would take a lot of work machining, drilling and tapping the parts to assemble this beam. If it does warp when laser cut, then there really isn't much he can do to straighten it out during assembly of that beam. We all know that mounting profile rails directly to a warped beam is unwise. You could instead purchase an I beam or C channel. Bolt additional pads to mount the rails to and have them machined flat.
Don't get me wrong. It all can certainly be done as designed and it can be done well. It's just not a design that I would recommend given the difficulty of fabricating when off the shelf steel profiles could be used with as good or better results.
And as for aluminum extrusions being sufficient, they most certainly can be. They are also not nearly as challenging to fabricate a machine with.
