587,125 active members*
4,193 visitors online*
Thread: new cnc mill
Results 1 to 20 of 20
    Feb 2009
    118
    new cnc mill
    Hello ,
    I present my new build , a small cnc milling machine ( still work in progress ) .
    Started building about 3 months ago , still waiting for some components ...
    For the time being , just pics ...lots of it . Here it is , from start to present :
    Mar 2014
    264
    Re: new cnc mill
    Welcome back ! The shop still clean as hell !
    Envoyé de mon GT-N7100 en utilisant Tapatalk
    Jun 2016
    3
    Re: new cnc mill
    Your creations are more than milling machines, they are also beautiful works of art and you could command a very nice price for these fine pieces!.
    Jun 2009
    251
    Re: new cnc mill
    I have to agree with Brigen.
    Regards,
    Tom
    Feb 2007
    4553
    Re: new cnc mill
    Really Nice...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Feb 2009
    118
    Re: new cnc mill
    update ...
    mockup ready ... next tear it apart and start final assembly ... hope to make a video with test cut and movement in about a week or so ...
    Jun 2016
    3
    Re: new cnc mill
    Very thoughtful layout of the lighting in the cabinet. Looking forward to the video test cuts.
    When tightening down the linear rails on the aluminum - are these precision ground aluminum plates? May I ask how are you maintaining perpendicular and parallel in all three axis? My understanding is the linear rails and blocks are so precisely fit that because there is almost no play even being off a few microns from one rail to another can lead to grabbing. Your thoughts / experience appreciated.
    Feb 2009
    118
    Re: new cnc mill
    I use only MIC-6 6061 T6 aluminum plates . Theese are precision ground , very small tolerances in thickness .
    Hope to get about 0.025mm work precision ( 1 thousand of an inch ) . For me , that's enough ...
    The rails are parallel to each other within 0.01mm , and the 90 degrees angles are controlled within 1 minute of a degree . Again , for me
    and for the work precision I want , is quite enough ... Of course , because the structure of the machine is made of aluminum , the main problem
    are vibrations ... this will affect the quality of the finish , and the final dimension of the part that's being cut . So , in the end , you can not
    expect too much from this kind of DIY machines ...
    The important thing here is the journey , not the end result ... paraphrasing of course .
    cheers.
    Jun 2016
    3
    It will be interesting to see the first cuts. In your previous post a while back I recall you mentioning you wanted to make something that could cut aluminum better than your gantry system so a comparison cut / hole / face mill would be interesting to see.
    I say in the case of you mills, any shortcomings in precision are iffset by aesthetics.
    Aug 2008
    1186
    Re: new cnc mill
    Gorgeous! Looking forward to seeing it in action!!
    Apr 2009
    5516
    Re: new cnc mill
    Quote Originally Posted by brigen View Post
    Many linear rail can withstand up to .005" out-of-parallelism....
    Jan 2005
    1943
    Re: new cnc mill
    I like your wall decorations.
    Feb 2009
    118
    Re: new cnc mill
    Job finished . Here is a small movie with my first chips ... bad movie , out of focus sometimes , sorry ...
    https://youtu.be/ihUbePzfDUI
    cheers.
    Mar 2004
    636
    Re: new cnc mill
    Very Nice!
    Jan 2008
    1538
    Re: new cnc mill
    Nice.
    You should always ramp plunge moves though.
    Jul 2014
    215
    Re: new cnc mill
    Very nice build Katran. It's always nice to see those chips being cut. I'm curious if you have tried cutting any steel materials on your mill. Are those aluminum extrusions stiff enough for that or is this machine just dedicated to doing aluminum or softer materials.
    Best wishes,
    Paul
    Feb 2009
    118
    Re: new cnc mill
    The machine is dedicated for aluminum molds only ...no steel materials . The aluminum extrusions can not be stiff enough for that ...
    Thanks .
    Jun 2009
    251
    Re: new cnc mill
    Nice, as always. I do admire your attention to details and the persistence in making such nice looking machines.
    Mine end up looking .....not so good!! I am getting better at it, though. Also, mine never break down, so not good for business! (chair)
    Tom
    May 2016
    1
    Re: new cnc mill
    hi.
    Nice CNC.
    What is working size of this CNC
    Jun 2018
    1
    hello, I interested in your work, you could not share the exact size of aluminum products and the thickness of aluminum, too Thank you
  1. Replies: 2
    Last Post: 05-16-2016, 01:08 AM
  2. Replies: 0
    Last Post: 03-27-2016, 04:52 PM
  3. Replies: 0
    Last Post: 02-13-2016, 04:47 PM
  4. Looking to buy this mill, Seller States Bridge port mill BOSS 7.2 retro
    By swill008 in forum Bridgeport / Hardinge Mills
    Last Post: 07-05-2015, 07:09 PM
