587,626 active members*
3,246 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Need two 12mm 4 Bolt flange bearings
Results 1 to 6 of 6
    Sep 2003
    1475
    Question Need two 12mm 4 Bolt flange bearings
    I have looked on various sellers on Ebay and Amazon and cannot find any 12mm 4 bolt flange bearings, tons of 1/2" though.
    I need two of them.
    Can anyone tell me where I can get a couple.
    Hager
    May 2006
    954
    Why not just go with 1/2" http://www.thebigbearingstore.com/se...-Flange/Detail
    and make it work? 12mm is what, .47? 1/32 isn't a lot of play especially with 2 set screws.
    Sep 2003
    1475
    Question Need two 4 Bolt 12mm Flange Bearings
    Quote Originally Posted by bp092 View Post
    Thanks for the suggestion but as you say 12mm = 0.474" that's 0.026" smaller than 0.500".
    This would put added stress on the ball and the flex connection, I want to build as best I can.
    If I can't find a 4 bolt 12mm flange then I have two options, (1) make a flange using HDPD (SP???) or (2) turn the 12mm portion down to say 0.250" and sweat a sleeve over it to bring it up to 0.500". The latter is what I'm leaning to.
    See Drawing below.
    When you are building out of found inexpensive parts there is always challenges.
    Hager
    Oct 2008
    44
    Post
    (815)-654-1154
    Address9926 N Alpine Rd
    Machesney Park Illinois, 61115
    Berry Bearing Co. Has what your looking for. We had alot of metric machines at the plant. We called them and could get the bearing by COB.
    They don't have a web page that I could find. Also try other bearing suppliers in your area.
    Sep 2003
    1475
    Quote Originally Posted by Fiddlemaker5224 View Post
    (815)-654-1154
    Thanks Fiddlemaker,
    I'll give them a call.
    Hager
    Oct 2008
    44
    Post update
    Berry Bearing is part of Motion Industries.
    https://www.motionindustries.com/mot.../mi/motion.jsp
    I found his section.
  1. Phoenix Modification 2.0: Flange Bearings
    By Mr.Chips in forum DIY CNC Router Table Machines
    Last Post: 01-25-2011, 01:04 PM
  2. 12mm rods and bearings. first machine question
    By srmaietta in forum DIY CNC Router Table Machines
    Last Post: 04-10-2007, 02:26 AM
  3. Is 12mm/2mm ballscrew for Z-zixs router undersized?
    By NC_jimbo in forum Linear and Rotary Motion
    Last Post: 03-26-2007, 08:24 AM
  4. Where can I find a 12mm 2.5 pitch lead nut
    By woodturn in forum Benchtop Machines
    Last Post: 03-14-2007, 05:17 AM
  5. Bolt hole spacing on a flange
    By Bill Wann in forum Autodesk
    Last Post: 03-15-2006, 02:11 PM
