587,194 active members*
3,160 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Need a spindle drive repaired in the UK.
    Apr 2017
    0
    Morning, we have a Haas VF-0 CNC mill.
    It has error codes 119 and 123.
    Phoned Haas and after hearing the error codes said we would need a new drive, cost was in five figures.
    A drive company has already looked at the drive and changed the capacitors but we still have the same fault.
    So we are looking for a recommendation of a company in the UK to repair this drive. Unless someone have an easy fix?
    Regen resisters: 8.2 ohm
    DC voltage is 330v (2 line voltage)
    640C is 3.3v
    No shorts on motor.
    Thanks.
    Mar 2014
    133
    Re: Need a spindle drive repaired in the UK.
    Those drives are a dying breed. If it's a Brushless machine you're better off getting the vector drive upgrade if you want to keep this machine alive for another 10 yrs.
    Mar 2014
    133
    Also, there are very few companies that will repair this drive. There are some companies in the United States,but to be brutally honest it'll be in the 5 figures to repair it correctly as well.
  1. I.H. Belt drive conversion spindle drive sleeve gear
    By Roadstercycle in forum RF-45 Clone Mill
    Last Post: 04-23-2018, 12:43 AM
  2. MISSING AC SPINDLE DRIVE + 3 AXIS SERVO DRIVE
    By Affaq999 in forum Vertical Mill, Lathe Project Log
    Last Post: 02-20-2015, 03:50 AM
  3. Replies: 0
    Last Post: 01-25-2015, 08:20 PM
  4. Repaired video
    By IQChallenged in forum Videos
    Last Post: 01-20-2010, 02:15 AM
