587,089 active members*
3,151 visitors online*
Results 1 to 5 of 5
    Jun 2015
    1
    Cool Need someone to make g-code for me.
    Hi my name is Mike and I have a cnc router ready to go however I need to have the g-code created for me and it should be very simple. I am willing to pay a set or hourly rate and if interested please let me know and we can talk.
    Apr 2004
    5739
    Re: Need someone to make g-code for me.
    It's not that hard to create your own G-code, but it is difficult to create it for someone else. Each project has its own set of parameters, such as a certain material, a particular cutter, the quirks of your own special machine, the placement of your clamps and fixtures, the way you want the toolmarks to run, etc. that make being able to make changes on the spot essential. It's harder to explain all these things to someone than to just implement them in a CAM program. It's not really that hard to do. I'd suggest starting with a demo copy of DeskProto, which will work for free for a month, and beginning with some relatively simple projects, working your way up to more complex ones. Spending your time this way will be more productive than spending your money trying to get someone else to do it for you.
    Andrew Werby
    ComputerSculpture.com ? Home Page for Discount Hardware & Software
    Andrew Werby
    Website
    Jun 2014
    13
    I can create for you g-code
    You can draw and create Gcode or import DXF and HPGL files to create Gcode files with the Demo Version of SuperCamXp.
    This is a link to the demo download.
    SuperCamXp Demonstation Download
    This is a link to a video on how to create the G code files from a simple drawing.
    Super Tech's SuperCamXp Menus Links
    Or you can use SuperCamXp with the ArmPod and there is no need for Gcode files because the machine will work directly form the drawings.
    Hope that helps..
    Dennis Bohlke
    Super Tech & Associates Main Web Home Page
    Jun 2014
    13
    The links appears "This page cannot be displayed". If you give me a sample of g-code machine reads, the drawing you wish as DXF or CAD model, the list of tools in use and the type of control I can generate the g-code for your machine.
    This is my e-mail
    [email protected]
    Best regards
  1. how to make embroidery from g code???
    By benjon in forum LinuxCNC (formerly EMC2)
    Last Post: 07-08-2015, 02:21 PM
  2. Replies: 5
    Last Post: 04-20-2012, 05:13 AM
  3. Simple G-code to make, please help ):
    By waxmund in forum G-Code Programing
    Last Post: 10-07-2010, 01:29 PM
  4. Cant make this code run properly
    By ganderboy in forum G-Code Programing
    Last Post: 10-30-2008, 10:36 AM
  5. Can you make G-Code With Corel
    By Biggermens in forum Uncategorised CAM Discussion
    Last Post: 10-30-2005, 04:15 AM
