I would apreciate some help setting up L100 VFD that is being used with Bridgeport. VFD was purchased used and installed about two weeks ago. This is my first time using VFD's, but once installed it runs the spindle fine(somewhat). By somewhat i mean that in lowest setting with pot it is running at 105Hz. How can i change this so it can go down to 0 or whatever it is normaly supposed to be?
Another question i have is about running relay(cnc4pc board C6 Varable speed control board) I have folllowed the instructions one the site, set it up in mach3 as instructed, but it still doesnt turn on the VFD, do i have to do anything on VFD side? here are the instructions i followed:
http://cnc4pc.com/images/Hitachi_L100.jpg
http://cnc4pc.com/Tech_Docs/C6-VSCB_Manual_Rev4.pdf
Thank you for any help,
Russ
