Re: Need some help
The problem you described is almost certainly an issue with your encoder not being recognized under load. I could not find a datasheet for that encoder because the URL is bad, but I am guessing that its current draw will be above 50mA. You can try powering the encoder externally with its own 5V supply and see if that fixes it or try using an AMT102-V encoder from DigiKey Electronics - Electronic Components Distributor. Any time it jumps like that it is because it is not detecting an encoder line, going into FAULT, resetting, and repeating the cycle.
Marcus Freimanis
www.geckodrive.com
