587,753 active members*
2,891 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > Need rotary / 4th axis help
Results 1 to 5 of 5
    Feb 2011
    36
    Attached is a crude wheel hub. I was using it to experiment with SprutCAM 4th axis. I managed to get all the spoke holes drilled easily enough using transformations. But I have two problems.
    1) Despite reviewing the Sprut 4th axis tutorial, I can't get the center slot cut. The green area are two selected faces, per the tutorial. And I have told it rotary machining. But look at the toolpaths--way off. It's not really rotary either. It's cutting one half, then rotary 180 to the other half. Not spinning round like the tutorial does. What have I missed?
    2) I have no idea what to use for the gear-like details around each side. What operations should I use? I tried pocketing and waterline, both were ugly.
    Thanks,
    Dave
    Aug 2009
    986
    Can you post the file here? I'd be happy to take a look at it.
    Frederic
    Feb 2011
    36
    Quote Originally Posted by TXFred View Post
    Frederic
    Thanks. Attached!
    Aug 2009
    986
    I tried it, and I didn't get the funky toolpaths that are in your sceenshot. It worked just fine here.
    I did have to go to Transition and change the Safe Level and Feed Switch level to 3.5" absolute in order to keep the cutter from going into the part at full rapid. But that doesn't appear to be related to the problem that you're having.
    I'm running Sprut Version 7, Build 1.5, Rev 45786. What version are you using?
    Feb 2011
    36
    Upgraded to latest and it's working. thanks!
    Dave
  1. A 5-axis CNC machine including a rotary axis
    By synthetiklone in forum CNC Wood Router Project Log
    Last Post: 07-12-2013, 09:32 AM
  2. rotary axis, y, c, and axis substitution
    By 60rock in forum Mastercam
    Last Post: 08-02-2011, 05:45 AM
  3. Tipping rotary haas rotary axis
    By mfpuller in forum Mastercam
    Last Post: 04-04-2011, 04:16 PM
  4. 5 Axis CNC with Rotary Axis on Table
    By Shooter7 in forum Commercial CNC Wood Routers
    Last Post: 09-20-2010, 04:33 PM
  5. Rotary head development 3 axis -> 5 axis
    By Mr Helmut in forum Mechanical Calculations/Engineering Design
    Last Post: 08-03-2010, 11:26 PM
