587,675 active members*
3,516 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Techno CNC > Need help with Z axis touch off plate
Results 1 to 4 of 4
    Sep 2005
    28
    I am considering making my own touch-off plate for a LC4848 machine but do not know where to connect the plate at the control board.
    If you know, or have a touch-off plate connected and can let me know what connector and pin, I sure would appreciate it.
    Ed
    Apr 2010
    0
    If it's a low power LC controller, you can connect the touchpad to pin 6 on the 4th encoder connector, its a DB15.
    Sep 2005
    28
    Thank you so much.
    Sep 2005
    28
    Touch off plate has been made and is working 100%
  1. Touch-off plate for CNC router?
    By CanSir in forum LinuxCNC (formerly EMC2)
    Last Post: 03-28-2019, 11:53 PM
  2. Z axis touch plate
    By spalm in forum Mach Software (ArtSoft software)
    Last Post: 10-08-2011, 07:03 AM
  3. electronic touch-off plate
    By project5k in forum Benchtop Machines
    Last Post: 02-25-2009, 08:20 PM
  4. Touch Off Plate
    By gunlocators in forum Benchtop Machines
    Last Post: 10-07-2008, 07:25 PM
  5. DIY pressure sensor ? - Touch Off Plate ?
    By deleteallusers in forum Mechanical Calculations/Engineering Design
    Last Post: 06-22-2007, 10:56 PM
