I'm adding adifferent controller to a cnc masters mill, however, I need a little help. hopefully there are others that have taken on this challenge. i did open the drivers they are definitely geckos 201's. So i pulled the geckos and matched them to a nice toroid , rectiifer and caps , c-11g bob, and I'm off Well , almost, I'm wanting to know if there is an easy way to tell which wires on the motors are the A+ A- or
b+ or B-. these motors look to be the ones that kelling sells, but there are no markings. They're 1200 oz/in 5.8 amps ot so, that I've determined by the resistor that was used on their( cnc master's ) board. There are 5 wire, but looks as if the yellow wire only goes to the ground peg that they used for their limit switch. The wire colors are red, black green and white.
In everything i've seen these colors don't match anything on any motors. I know if i used an ohm meter i can separate the coils, but it would be easier to know which was which, because once i assemble this in the case , it won't be as easy to disconnect and reconnect, if i'm wrong, at least without alot of ado.
all help appreciated.
thanks
Mark
