586,042 active members*
3,789 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > Need help to convert PDF DRAWING to DXF. to cut them on a CNC router
Results 1 to 10 of 10
    Jan 2012
    12
    does anyone know if there is a free program on the net to convert PDF to DXF?
    Jul 2008
    70
    Re: Need help to convert PDF DRAWING to DXF. to cut them on a CNC router
    I get .pdf drawing all the time. I print it out and Draw it in Bobcad. PDF is not a drawing of any type.
    Oct 2007
    1022
    I have never seen anything free
    Nov 2008
    642
    Look at inkscape
    Oct 2010
    1189
    If you found it let me know Thx thomas
    Jun 2008
    562
    This one is not free $229 USD but it works well for converting line type drawings in PDF to DXF, Print To CAD: Home
    I used it to convert several hundred pdf files to DXF. You may have to scale them to get correct dimensions but all in all it works well. Also a "free" trial is available
    Mike
    Jan 2007
    1795
    inkscape is free and import pdf files.. you can export to dxf or eps..
    Oct 2007
    1022
    I use print to cad and have had very good success ,but I prefer to use john walsh's drawing board to just copy pdf's or diagrams right straight to dxf files
    There is a spot here on the zone covering logic trace software uses
    Jan 2007
    1795
    sure it could work right.. they asking 230 dollar for..
    and convert just same like inkscape..
    I think for 230 dollar they should give a little bitty more than simply converting curves..
    little different inkscape is a fully working graphic program.. and conversion only one function beside hundred of others...
    original posters was asking for free program..
    is there a free version of the print2cad?
    Dec 2008
    4548
    Quote Originally Posted by WILDMAN2 View Post
    A pdf can contain a lot of disparate data. One of the main entities that it can contain is "vector data", which IS drawing data (Like that done in Corel, Illustrator or inkscape).....
    If you have BobArt in your package, It can import vector data from pdf's.....
    If you don't do it a lot, you can use something like this too...
    https://cloudconvert.com/
    This will do a few free ones a month for you...
    Again, a pdf can just be a "bitmap" too, which is nothing to convert to dxf....
  1. Convert dwg drawing to stl
    By LioCAD in forum Autodesk
    Last Post: 10-27-2014, 07:42 AM
  2. How to Convert 3D Drawing DFX to GCode?
    By pa2012 in forum G-Code Programing
    Last Post: 06-07-2012, 04:52 PM
  3. how do I convert a drawing into G code
    By crob09 in forum Uncategorised CAM Discussion
    Last Post: 11-24-2011, 11:03 PM
  4. 2D drawing convert
    By hitu_vk in forum Uncategorised CAD Discussion
    Last Post: 08-18-2008, 07:04 AM
  5. Convert drawing for use in BobCAD-CAM 2007
    By bobby1 in forum BobCad-Cam
    Last Post: 04-24-2007, 06:10 AM
