587,369 active members*
3,360 visitors online*
Results 1 to 4 of 4
    Sep 2011
    94
    Need Help with large relay
    Attachment 247186
    Hello I am attempting to setup a relay to control my dust vac and am having problems that make no sense to me. My older machine has a cnc4pc relay board I setup so I purchased one for the new machine however it was not heavy enough for the load(no starting capacitor) kill a watt shows it draws 60 amps on start up briefly so I purchased a 80 amp nominal ssr relay off amazon.
    With the input connected I get continuity like I am supposed to on the top legs and open when disconnected, so far so good. But when I connect a small load (battery charger) it stays on all the time, when I connect the dust vac the motor turns over slowly and the extension cord gets hot. I had thought originally that my relay was bad or it was just overloaded however this is my third relay and am still unable to get it to work.
    Dec 2003
    24223
    Re: Need Help with large relay
    You have a DC type SSR there, if your motors and your battery charger is AC!
    You need a AC SSR output type.
    Al.
    Albert E.
    Sep 2011
    94
    Amazon lists some as being DC -AC and AC -AC I am guessing the second one is correct?
    Dec 2003
    24223
    You need low voltage DC control (input) and AC output (motor).
    Yours shows DC - DC.
    Al.
    Albert E.
  1. K2 relay
    By cr2 in forum K2CNC
    Last Post: 07-24-2011, 04:01 PM
  2. 24Vdc Solid State Relay not the same as mechanical relay??
    By cjchands in forum CNC Machine Related Electronics
    Last Post: 11-10-2010, 07:40 AM
  3. Using a solid state relay as a main stop relay
    By garagefela in forum CNC Machine Related Electronics
    Last Post: 02-26-2010, 11:27 PM
  4. keep relay
    By guhl in forum Fanuc
    Last Post: 08-17-2007, 01:22 PM
  5. Need Relay help...
    By CarveJunky in forum CNC Machine Related Electronics
    Last Post: 07-20-2005, 02:52 PM
