587,449 active members*
2,936 visitors online*
    Mar 2009
    43
    Question Need help in hydraulic oil
    Dear friends,
    recently we purchased VTL from korea. in power pack they mentioned oil grade in korean language. i need help to find what oil they mentioned, kindly find the attachement for oil grade.
    Regards,
    keyan
    Jul 2007
    38
    I can't read Korean but the 32 on the end indicates they are probably using a #32 hydraulic oil. I deal with a lot of Japanese equipment and they seem to do the same thing when marking equipment, i.e. a symbol and number on the end
    good luck
    Jul 2009
    80
    It should be a Viscosity Grade 32
    which is Hydraulic oil.
  1. Conquest T-42 Hydraulic
    By imac in forum Hardinge Lathes
    Last Post: 04-27-2010, 09:04 PM
  2. Hydraulic/Air Chuck?
    By Hellbringer in forum Haas Lathes
    Last Post: 03-06-2008, 10:09 PM
  3. hydraulic help
    By byoung0454 in forum Mechanical Calculations/Engineering Design
    Last Post: 01-09-2008, 05:29 AM
  4. Hydraulic Problem
    By bherr in forum Bridgeport / Hardinge Mills
    Last Post: 06-28-2007, 10:07 PM
  5. Which Hydraulic Oil do I use?????
    Last Post: 06-13-2007, 02:01 AM
