587,380 active members*
3,767 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > EDM Discussion General Topics > Need help getting a Fanuc Robocut Alpha running
Page 3 of 3 123
Results 41 to 45 of 45
  1. #41
    May 2010
    61
    Re: Need help getting a Fanuc Robocut Alpha running
    here is what I found on the tension. I tried sending in in PM but said your inbox was full. Hope this helpsAttachment 475792Click image for larger version.
  2. #42
    Mar 2016
    325
    I don't know why this happened. I had just few messages in PM's.
    Thanks for settings info, it will surently help.
    I thought every alpha has a possibility to cut in submerged mode...
  3. #43
    May 2010
    61
    I don' know if they are all or not but I know mine the drain system is such that it cant. Like the back is open for the water to drain out of instead of like a tank with a drain hole. There's not a button to fill or drain tank either. Friend that came up gave me some good ideas and explained some of the power settings that I am going to try out. I was doing a few things backwards. Hopefully I can get it all figured out. He explained the De ionizing system and stuff also. If you can send me a PM with an email and a physical address I'll send you a copy of this class workbook if you want. it has some things in it that are explained better than in the manual.
  4. #44
    Mar 2016
    325
    I would gladly see what it looks like, and also share what looks like cabin for submerge cuting. I tried to cut above the surface, but it was like trying to find a compromise between eficient cuting and splashing all around.
  5. #45
    May 2010
    61
    Quote Originally Posted by steryd View Post
    I can understand that for sure. I wish this one was submerged.... I did learn that I have been going to wrong way to speed the cutting by upping to voltage. The guy this weekend showed me that lowering the voltage made it go a little faster. Haha there's a lot to these that doesn't go logically
Page 3 of 3 123
  1. Fanuc Robocut alpha oc
    By BRAIN-HURTS in forum EDM Discussion General Topics
    Last Post: 12-16-2020, 12:03 PM
  2. EDM Cutting Conditions For FANUC Robocut (alpha)-OC and (alpha)-OiA
    By aaronell in forum EDM Discussion General Topics
    Last Post: 11-02-2015, 07:01 PM
  3. Fanuc robocut alpha-OiE
    By pife82 in forum EDM Discussion General Topics
    Last Post: 08-15-2015, 06:22 PM
