My lathe post is posting out in feed per inch, I need it to post feed per rev.
I add chip feed rate according to Esprit Help and no go. this is really no good.
Hey dcoupar, I'm using Esprit 2009 and Per Revolution is set for .002 Esprit help says "Use the formatable code keyword CHIPFEEDRATE". I edit the ASC file and still get feed per inch. This is for a TL-2 HAAS Lathe.
Thanks dcoupar, this works fine.
did you get this fixed?
Maybe a stupid question , dou you have set the feed rate in the general setting on feed per rev or feed per minute , where is this happening specific cycle driling , od roughfing ? let me know to check if I can help you
Did any one have post for cnc swiss screw machines ASC
EMS file machine set up?
For stars tsugamis or Citizens?
Hello
I'm starting to work with Esprit CAM
Any of you have any Esprit cam post processor for swiss lathe?
Possible to send by email - [email protected]
I would really appreciate
thank you
