587,158 active members*
3,086 visitors online*
    Dec 2020
    2
    Need help! CnC router Syntec 6MB alarm
    My company have a cnc router Syntec 6mb and an alarm error keep showing "MLC 84 (R45. 3) PLC Alarm"... The spindle is rotating just fine.. But the machine doesn't want to move..Anyone knows what is wrong with the machine? What should i do to solve this problem? Thanks
    Aug 2009
    655
    Re: Need help! CnC router Syntec 6MB alarm
    Unfortunately not sure. I looked through the manual I had but error code mlc 84 is not listed so I guess it's a machine manufacturer added code.
    I'd check all the sensors you can think of. I had a weird one once where it was a loose sensor that reported that the tool changer was retracted.
    Good luck.
    Sent from my Pixel 3 using Tapatalk
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
    Jan 2012
    6
    Quote Originally Posted by gfacer2 View Post
    Good luck.
    i have same error
    6mb also
  1. Replies: 7
    Last Post: 01-25-2024, 04:42 AM
  2. Need help! CnC router Syntec 6MB alarm
    By Farkir in forum WoodWorking Topics
    Last Post: 12-31-2020, 03:31 AM
  3. AL 90 ALARM CNC LATHE SYNTEC TA
    By SUPERMAN2017 in forum Chinese Machines
    Last Post: 05-11-2018, 05:24 PM
  4. Syntec 6mb tool change alarm mlc 76
    By Bascil in forum Chinese Machines
    Last Post: 05-11-2018, 01:38 AM
  5. Need Help, syntec MLC alarm 76 R44.11 PLC alarm
    Last Post: 01-03-2018, 12:48 AM
