587,446 active members*
3,165 visitors online*
Results 1 to 11 of 11
    Nov 2011
    0
    Need help with chinese laser
    Hi
    I am new to this forum as well as laser cutters.
    I just received my JC6040 80W laser from China but cant get it to work.
    If I try to cut something I can hear a noise at the tube but it does not cut.
    My waterpump is working fine so it is not a water problem.
    Is there a way to test if the power supply and tube is OK.
    Regards
    Freddie
    Jul 2011
    0
    Good luck Freddie
    We have had a real struggle getting ours to work and found that the company we purchased from were BUGGER ALL help.
    Hoping someone here can help you out.
    Nov 2011
    0
    Smile
    Hope you can help me because seller is no help at all.
    Freddie
    Is there a laser came out from the focus lens?
    Once you turn on the laser and press "test", did you find a pink line inside the tube?
    Nov 2011
    10
    Laser repairs/ chinese laser
    When I bought my laser I was going to get one from china but found a company near by that sold them. I spoke to them and they said they repair a lot of lasers from china. They are called HPC laser, have a look at their site they might be able to help.
    Amy(chair)
    Apr 2003
    1873
    You need to have the power set to no less then 15%, I'd try 20%.
    What is the power set to at the key pad?
    Under laser set what is the milliseconds set to?
    You should see a purple/pink laser at the center of the tube when it is fired.
    Ken
    Sep 2011
    296
    Hi Freddie,
    Have you succesfully set up the laser? You need to check that. Sometimes customers didn't equipped the laser tube correctly, so the laser tube didn't work. If you did as the right way, maybe there were some quality problems with the laser tubes.
    I have uploaded a video of how to set up the laser and i have sent the link to this forum before. You can click below to watch
    http://www.tudou.com/programs/view/MzazGBoZ8fs/
    Is your 80W laser tube of Reci Brand? If so, the laser tube can have the warrenty time for 10 months. You can contact your seller to change a new laser tube for you if there is quality problems.
    Hope you good luck!:cheers:
    Jun 2009
    37
    A high pitched whine will indicate the tube is getting power to fire. Like others have stated, there should be a pinkish/purple glow along the tube. This is the plasma created by the high voltage in the tube.
    Place a piece of paper over the "business end" of the laser and hit the test button. If it burns a neat little hole in the paper, tube's firing.
    Next move to the first mirror with the paper and repeat. Is the laser hitting the first mirror? Try the second mirror (the one mounted on the gantry). Then try the one at the laser head. I'm thinking your adjustment is hosed and the laser is flying off somewhere outside of the normal beam path. If it's misaligned, it won't make it to the head. Work through that and see how things go.
    Nov 2011
    0
    Smile
    Hi
    Thank you for all you advice. I tried everything but all I hear is a crackling noise at the tube but no pink light.
    I have tried also with a paper at the tube but nothing is happening.
    I will I know if the power supply is giving enough power?
    Freddie
    Quote Originally Posted by Freddie1 View Post
    Hi
    Freddie
    Sorry to say this Freddie but the crackling sound at the tube usually indicates that the tube is dead. You should, I think, plan on getting a replacement tube.
    Tweakie.
    CNC is only limited by our imagination.
    Jun 2011
    0
    Hi Freddie,
    Maybe something wrong of the laser tube, it is good for your to upload some photoes of your laser.
  1. Add US made laser module to Chinese laser?
    By glintid in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-02-2012, 08:43 AM
  2. should we buy this chinese laser ??
    By albo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-27-2011, 07:21 AM
  3. Where to buy a Chinese 80W Laser
    By PaioX in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-17-2010, 08:57 AM
  4. Chinese laser
    By Gary123xyz in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-25-2010, 08:00 PM
  5. Chinese Laser
    By FMA1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-19-2008, 12:38 PM
