ok so the machines i'm using are not exactly off the shelf cnc machines, and i need to edit my post to output the canned cycle command on each position i need to drill rather than once at the first location then just the points there after.
i've got backups of the post all over the place so i can edit one of them at will. so guess if you need to. i'll go and get the current control code if i can pick it out, but there may be a way to do this with the machine control definition?
