Originally Posted by
mondo50m
Did you make sure that the lock next to the dimensions is unlocked? Just click on it to unlock it. Then you can change either dimension. If it is locked, when one dimension is changed the other will change accordingly. I misread your post and what you needed. I have had similar problems setting a different size on boxes like that. When you change a dimension in one direction, it changes the size of the tabs and the inserts, so they no longer fit together. It can be done but you have to do one part at a time. The go through the whole part and change the tabs and cutouts to accommodate the smaller or larger size. It is a pain in the butt.
Milt
