I recently picked up a 1982/83 CNC Lathe that came out of a R&D lab with low hours. The issue with it (currently) is it is tape loaded and I need to bypass the tape reader so I can load codes direct from a PC.
Problem is I don't know much about tape readers or options for bypassing them, I'm reading up on them but its rather confusing to the uneducated so I am hoping someone here might be able to point me in the right direction or offer suggestions that they (or others) have used before. I have retro fitted a few machines but they were ground up and not just bypassing something like a reader, so I am not to shy about getting in and splicing wires, running new cables and that sort of work. My understanding at the time I bought the machine was it was in good working condition, that being as it is I would like to keep the control system in it verses gutting and reworking form the ground up. (though I do not care to keep the reader - if there is a easy cheap way to bypass it that results in its removal/loss of use I am not opposed to that at all)
Cost is a factor at this point - so cheaper solutions are better in that regard but I am open to any and all solutions/ suggestions or help that can get me from point A to point B (Having a machine that I can load/drip codes to without the use of the tape reader). I was able to locate this one : http://www.adrco.com/GE10HLX.htm and have read good things about ADRCO but, again, the price makes it prohibitive at this point.
Thanks in advance,
~Terry S
HBA
