587,426 active members*
4,348 visitors online*
IndustryArena Forum > CAM Software > Surfcam > ncEdit quit working
Results 1 to 4 of 4
    Apr 2007
    2
    Post ncEdit quit working
    My surfcam editor quit working. This was caused by an update to windows. I uninstalled the last 5 updates and it started to work again.
    Aug 2006
    259
    yea happened to me too, on a couple programs.. if the error you were recieving was this:
    The system DLL user32.dll was relocated in memory. The application will not run properly. The relocation occurred because the DLL C:\Windows\System32\Hhctrl.ocx occupied an address range reserved for Windows system DLLs. The vendor supplying the DLL should be contacted for a new DLL.
    then do this hotfix
    hth
    Apr 2007
    2
    Smile Worked Great
    The hotfix worked great Thanks
    Jun 2007
    1
    Solidworks 2007 to surfcam 2004
  1. 6M quit tool changing
    By Drew in forum Fanuc
    Last Post: 01-23-2007, 07:32 PM
  2. Help on import, radio button quit!!!
    By XYZ machine in forum GibbsCAM
    Last Post: 01-11-2007, 10:24 PM
  3. Spindle quit running w/ c axix fault
    By TomCNC88 in forum Fadal
    Last Post: 07-28-2006, 04:07 PM
  4. BP Boss 5, Z-axis quit, help me please!
    By rsr911 in forum Bridgeport / Hardinge Mills
    Last Post: 12-20-2005, 06:29 AM
